Firstly i inserted a cd in my cd rom but i did not see any display on my window after i checked in device manager and found that it was having something missing issue so i had to un install it and searching for a new software so please help me to install it
  • 2,229 Answers
You don't need special drivers to have the CD ROM work. They are included in Windows.
If you are having system file issues, though, you may have to run the following:
At the start button click RUN
Then type SFC /scannow
It will check your system files.
You didn't say what it told you that was missing, so I'm guessing here.
Posted on Apr 02, 2011
My dvd rom is not working becouse an error in driver HPDVDRAM GS30
Optical drives are more forgiving.
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install.
Dec 12, 2012 | HEWLETT-PACKARD HP ENVY 15 Series Notebook...
Dvd writer not recognising any disc.just says insert disc
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 06, 2012 | Computers & Internet
I have a dell inspiron 6000 and the sony dvd/cd rewritable drive model DW-D56A does not load cd or dvd when inserted but it does light up and eject when pressed in my computor
Oct 11, 2012 | Computers & Internet
My laptop says I don't have a DVD burner but I do. How can I reinstall it?
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a disc the drivers could be on it
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
dont forget to vote
Feb 19, 2011 | Computers & Internet
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
Can't install HP 4355 on windows 7
Installing HP 4355 on windows 7 is pretty easy ,kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,very minute but technical tip is to connect the printer first and insert program CD for printer in the rom drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in nex few minutes your device shall be ready to use.
Incase there is problem with installation with CD kindly go to manufacturers website and download windows 7 compatible drivers.
For Safe Computing Knidly keep your antivirus updated and firewall is on.
Thanks And Regards Kindly rate this solution
Feb 25, 2010 | HP Officejet 4355 All-In-One InkJet...
Averatec 3200, cant find DVD Rom driver in "My Computer" or "Device Manager" When I put in a CD I can hear the disk spinning but it never loads. I deleated the upper and lower filters and restarted the...
Make sure the BIOS is 'seeing' the drive. Reboot your pc, press F2 as soon as it starts to boot (Or watch your screen and the POST will display which function key to press to enter setup.) If the BIOS is NOT seeing the drive, you may need to a) replace the drivers for the dvd or b) replace the dvd rom itself. (I recommend the drivers first.) Please repost your results and we will continue to monitor your progress.
Good Luck
C2Solutions
Sep 04, 2009 | Averatec 3200 Notebook
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Optiarc cd-rw crx880a ata device: This device cannot start. (Code 10)
Did you try to click "Troubleshoot" on the page that reported "cannot start" ?
Did you try to click on the device, and choose "uninstall" ?
Then, rebooting Windows should cause Windows to "find new hardware", and properly configure the DVD/CD drive.
May 22, 2008 | Microsoft Windows Vista Ultimate Edition
CD drive not displaying in windows explorer
sure..sounds like you may need a new set of drivers.
uninstall the cd from device manager, after getting new drivers from cd maker's site or computer makers site.
Mar 13, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
