Question about Briel Breil Bw0429 Milano Chrono Watch for Women
A Milano woman's bracelet watch (slot #B).....problem.....how to make the metal watch band smaller.
  • 2,334 Answers
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes
Posted on Apr 04, 2011
  • steve_rumsey
    steve_rumsey Jan 21, 2012
    This was a great help with a different Breil watch, thanks Arturs.
My watch band is too large. How do I make a metal expansion bracelet smaller
There are two ways.
First is to remove links.
Second it to move the pin in the clasp to another hole. Mine has 8 holes for this and you can see them in the side of the clasp. Use a pin to push the pin inwards as they are spring loaded. Do this work on a table with a cloth on it. If you drop the pin on carpet, they can be hard to find.
Nov 06, 2016 | watch band Watches
Is it possible to convert the resin band strap of casio GS1001 to metal bracelet? If yes, where can I get the metal bracelet?
I have just found this site, it has all sorts of watch straps for all casio watches.
I am sure that you will find it useful
www.casiosalesandservice.com/starasp/a=3&dept=cwband&class=gshock.
Feb 20, 2012 | Casio GShock Giez watch #GS10011A Watch...
Watch band is too large.
mcdevito75 here, You can click on Repair Services at the bottom of the page right here on fixya, once there type in watches.
Jun 20, 2010 | Relic Silvertone Bracelet Watch for Men
I'm trying to find out the measurment of the band of the watch because I want to replace it, and althoug I measured it myself, I find different measurments on the internet
Measure between the lugs, (where the currently installed bracelet/strap is installed. It should be measured in millimeters as that how all straps/bracelets are measured. Standard men's widths are 20, 22, 24 and some 26mm. There are of course, variations like proprietary bracelets and straps made to fit watches which will only accept the proprietary size made for it. These are usually much smaller (18, 14, 16mm) and integrated into the watch body design.
Jun 07, 2010 | Citizen Perpetual Calendar BL5260 50E...
I have a Sweda watch with a link type band and I need to make band smaller.
Click on my profile (escapement), then click on Tips and Tricks. There you will find explanation how to remove or add bracelet links. Rate me, plz.
Feb 11, 2010 | Bulova Watch
How do you remove a link without using any tools
You don't say much in your question ...
So ... I'm guessing ...
I'm guessing you have a watch with a expansion band that has removable links.
I'm also guessing it has a snap fastener and you have already made your band smaller through adjusting that part of the bracelet.
I'm guessing that yours is of a similar design to several I have owned and/or adjusted for others.
I'm guessing you have a paper clip in your home or office and ...
I am also guessing you never thought of a paper clip as a tool.
Straighten one leg of the paper clikp and pop out the little keeper on two of those links, reattach the loose ends for a smaller bracelet. There should be a little arrow pointing in the direction you should push the little clip/keeper.
I hope this helps you make your bracelet the size you need it to be.
Thanks for your question at FixYa.com
Jan 08, 2010 | Watches
How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Jul 29, 2009 | Casio Watches
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
Good luck
Dec 21, 2008 | Timex 2J611 Watch
Briel Breil Bw0429 Milano Chrono Watch for Women Logo
237 people viewed this question
Top Briel Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Briel Watch Expert? Answer questions, earn points and help others
