Question about HTC S710 Smartphone
HTC S710 I turn it on It opens the HTC welcome screen It then opens the Windows Mobile screen....and stays there for sometime unable to load windows It then jumps back to the HTC welcome screen It then opens agains the Windows Mobile screen....and stays there for sometime unable to load windows .....and this goes on and on and on...but the phone will not load windows and start working! I have tried removing the battery and turning it on again, but the same problem occurs. PLEASE HELP!!!
  • 25 more comments
  • msvcontact_i Apr 03, 2011
    I don't want to restore to factory settings yet. Can't we just install again the software for Windows?
    And one more thing. I don't understand your instructions. You say: "Press and hold the left and right soft keys. Power the device on while holding these keys".You must explain in detail. Which keys? But as I said I want to AVOID restoring. Please suggest someting else.
    Thanks
  • Anonymous Mar 11, 2014
    bottom draw too cold
    How I replace the timer on my Whirlpool Quiet III?
    Microsoft Office 2013 Home And Student Edition product key
    Trying to open the blender but got only 3 screws out. The 4th screw need a special screwdriver. What is it called?
    minolta bizhub c20
    the upper radiator hose is sucked
    Leaking under the tub were the drain and the tub connect
    Can I replace a powered mirror with a heated power mirror on a 2003 Dodge Caravan SXT
    there is 2 half circles with arrows on it
    passenger door lock actuator on 2005 mercedes slk 350
    1990 Honda accord brake fluid lReservoir emptied overnight 1990 Honda Accord brake fluid reservoir empty overnight
    fireing order/sparkplug fireing order 66 chevy 230 l6
    electric fuel pump keep running without car started Why?
    yamaha fzr directionals not working
    Car alarm went off but when you turn. The key the lights come on but engine don't turn
    how do I make the font size bigger
    Third row seat in Lexus 2004 Gx 470 does not stay tight when folded and held by velcro strap
    how to unhide pictures on a sony cyber shot camera
    2008 chrysler sebring sedan horn will not work
    I am buying a 2005 Chevrolet Silverado from Canada. How do I change the odometer reading from Kilometers to miles?
    He dryer not running but it makes three dings about five minutes apart
    speed
    Our electric furnace won't shut off even with thermostat off
    It says reading , but won't play when you press open it display open but won't then starts to read again . The only way I can get it to open is to unplug it then plug it back in then it will open
    my clippers have become very noisy and vibrates alot, half the time the scare my dogs
  • Anonymous Mar 12, 2014
    ford territory front diff bush mounts
    Genius:
  • 1,622 Answers
Hi, will give you steps to reset the cell phone and after resetting it, Both the soft reset and hard reset, and after that pass your comment and tell me if it work, So i will tell you want next to do. ok
Thanks and take care.
Restarting or factory resetting your phone
If your phone becomes unresponsive or sluggish, try restarting your phone and see if that helps. In case your phone has a persistent problem that cannot be solved, the last resort is to do a factory reset.
Restarting your phone (soft reset)
If your phone is running slower than normal, an application is not performing properly, or your phone becomes unresponsive, try restarting your phone and see if that helps solve the problem.
To restart your phone, simply turn it off and back on. If pressing and holding the POWER button doesn't work, then please remove the battery, wait for a few seconds, reinsert the battery, and then turn the phone on.
Performing a factory reset (hard reset)
If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on.
Note: Factory reset will not remove the data and files that are in your phone's microSD card.
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset.
Performing a factory reset via settings
The most convenient way to do a factory reset is via the phone settings.
1. From the Home screen, press MENU and then tap Settings.
2. Scroll down the screen and then tap Privacy > Factory data reset.
3. On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button..
3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
4. Press VOLUME UP to start the factory reset.
Posted on Apr 03, 2011
  • 3,530 Answers
Welcome to Fixya
Sound like the software is hanging up. Try to reset the phone back to original factory state. Please take not that this will delete everything you have thre inside the phone.
  • Power the device off. Press and hold the left and right soft keys. Power the device on while holding these keys. Follow the on-screen prompts to factory reset the device.
  • Thank you for using Fixya!
    Posted on Apr 02, 2011
    My htc S710 it downloag earthgoogle
    you can access it by going to settings then system tab then look for clock. or its faster if you have windows mobile center on your computer. connect your htc to computer and sync it using windows mobile center and its going to apply the date and seetings of your computer to the phone.
    Sep 03, 2010 | HTC S710 Smartphone
    I am running Windows 7 on my Laptop. How do I
    Download windows Mobile device center, then connect your mobile phone to the computer using the USB cable, Under Mobile Device settings click on connection settings.
    Download Windows Mobile Device center from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
    Apr 11, 2010 | HTC S710 Smartphone
    I cannot connect my htc phone to my lap top can you help me
    The HTC S710 uses either, ActiveSync or Windows Mobile Device Center depending on whether your PC's OS is Windows XP or Vista.
    Here's the link to the Microsoft web page for the download.
    http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
    Apr 07, 2010 | HTC S710 Smartphone
    Htc s710 having signal problem
    Select the network manually by goin to the network screen from settings.
    Jan 01, 2010 | HTC S710 Smartphone
    I want to connect my htc mobile with pc and i dont have cd
    if you are using Windows XP, download ActiveSync
    Vista and 7 users should download Windows Mobile Device Center 6.1
    Dec 10, 2009 | HTC S710 Smartphone
    My HTc phone doest gets on,eventhough i have put phone on charge also,some time light blinksand some times doest. what will be the problem?
    try hard reset or soft reset procedures, windows based mobile phones sometimes acts that way, just search google on how to hard reset your particular problem...
    Nov 10, 2009 | HTC S710 Smartphone
    Windows mobile unable to see the screen
    ASDFGSDFGGSFGGHGFGHGHJKYYYYYYYYYYYYYYYYYYYYYY
    Dec 12, 2008 | HTC Touch P3452 Smartphone
    UNABLE TO BOOT htc touch pro
    Yes. i solved the problem in my one
    press:
    vol down + restart + and the middle button = good :)
    Dec 03, 2008 | HTC S710 Smartphone
    Internet connection
    downloding speed is slow.i cant download any file
    Sep 30, 2008 | HTC S710 Smartphone
    HTC S710 Smartphone Logo
    93 people viewed this question
    Top HTC Computers & Internet Experts
    SANJEEV KUMAR SURI
    SANJEEV KUMAR SURI
    Tom Chichester
    Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
