Question about Kenmore Refrigerators
To whom it may concern: A some time leek in the front of the refrigerator. I have already check the water tube leading to the door not leek viable.
  • 415 Answers
I would check the defrost pan located behind the grille and maybe cracked or missing. This is a development of after sometime the frig will go into a defrost mode and as it thaws the frost and goes down a tube where it will evaporate some time later.
Posted on Apr 02, 2011
Water dispenser does not work, any time it is used water just drains out of bottom of freezer area onto floor. Ice cubes works
Hello Melissa;
My name is Peter. I am a retired field service refrigeration technician.
I am sorry to say you have a serious problem.
The water supply line to your ice maker runs up the back of your refrigerator from the ice maker solenoid. It is a separate water supply line.
Your water dispenser water line runs from the water dispenser solenoid under your unit and up from the bottom of you freeze door.
You have a plastic tubing leak within your freezer door. Calling a service company to replace the freezer door tubing - a good service technician would not replace the tubing - the damage has already been done.
The insulating material in your freezer door is soaked. The water in the door will cause the door liner to expand and crack. There is no way to completely dry out the insulating material.
The only fix is to replace the freezer door. So, $300.00+ for the door and $150.00+ for the service tech. No, a hair dryer will not do it.
May I suggest:
1.) Remove the bottom toe plate (Kicker plate) in the front of your refrigerator.
2.) Turn the leveling screws counter clockwise so you can pull the refrigerator out to get behind it.
3.) Unplug the unit.
4.) Remove the screws from the bottom cover.
5.) There are two connectors to the solenoid valve to the water dispenser. It is the larger diameter tubing running under your refrigerator.
This will disable your water dispenser. If you see cracks on the inside of your freezer door, seal them with a high temperature silicone adhesive.
If you elect to purchase a new unit, check out Sears Outlet (Scratch & Dent) Stores.
May 08, 2015 | Refrigerators
Leaking water from my refrigerator
Tubing in back of refrigerator leading to the ice tray is jammed with solid ice and whence maker timer calls for water back pressure prevents water from reaching the ice maker tray. Remove the tubing from the back and pull out the plastic tube that feeds the ice maker tray. Put the tube in hot water to melt the the and blow through it to make sure itis clear. When reinserting the plastic tube stick your head inside the freezer door and be sure the end of the tube overlaps the tray. The problem will be solved but the same thing will happen at some later date. I believe I solved this problem too. I got a roll of surgical adhesive bandage that's about a sixteenth inch thick and insulated the tube to prevent it from freezing again. It's been two months since and thank God it worked. The Frigidaire engineers could use this one.
Mar 01, 2015 | Frigidaire Professional Series PHS68EJSB...
I have a frigidaire refrig. Water collects under the fruit and veg bins. Any ideas why and what I can do would be helpful. It is not coming from the ice maker as it was doing this well before I put the...
Hi Erica, I am happy to assist you. I understand that water is collecting in the bins. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator bins. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
I certainly hope this troubleshooting tip resolves your concern. If you have any additional questions, please feel free to respond.
Aug 16, 2013 | Frigidaire Refrigerators
I have a frigidare 20.6 frig. approxiamately 10...11 yrs old im find water puddles on top glass shelf and bigger puddles at the bottom I cleaned as much as I could the fan is working help model...
Hello Donna, I am happy to assist you. I understand that water is collecting in your refrigerator. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 03, 2013 | Frigidaire Refrigerators
Every time the water starts to flow into the ice maker, the water pressure causes the line to disconnect. how can i keep my water line from disconnecting from the ice maker?
Buy a new one you have not connected it right. It's about $10.00 for the kit Just DON'T disconnect the valve leading into your pipe you already have or you will a non stop flow of water. Just replace the clear tubing. Turn of (flush) your water supply first then do the new tubing.
Feb 23, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Samsung fridge freezer mod no SRS2028 19.3 cu, ft
the water hose runs through the bottom hinge then to the dispenser. take the kick plate off of the unit and then check for leaks. theres a coupling down there that may be yoiur problem.
Dec 08, 2008 | Samsung RS2534 Side by Side Refrigerator
How to locate the water filter
Be sure to turn off the water valve before you start.
The water tube is probably kinked at the front lower left corner. Take the front lower grill off of the refrigerator and open the left door (freezer) and see if the translucent plastic tube is kinked where it comes from the bottom of the refrigerator and goes up into the door.
If it is, there is plenty of tubing to allow you to pull it out of the connector at the corner and cut off the kinked part and re-insert the tube.
Turn the water valve back on.
(This was the problem with my fridge and I had to show the Sears technician.  He had already told me to call a plumber and get a dedicated water line due to low water pressure!  Imagine the cost if I had believed him.  Works great - good flow and no leaks.)
Hope this helps.
Nov 23, 2008 | Kenmore 57029 Side by Side Refrigerator
Amana side by side
if the unit has been runfor some time prior to connecting the water the fill tube may be frozen up, he solution is to turn off defrost overnight with door open and then turn back on, flush water through when turned back on to clear old water and air.
Sep 02, 2007 | Amana ARS9266BS Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
