Question about Husqvarna Garden
My husky model 61 chainsaw won,t idle it keeps running way too fast when the throttle is released,tried adjusting carb but no good.
  • 608 Answers
You have an air leak or sticking throttle shaft
Posted on Apr 11, 2011
Chainsaw chain keeps running
This is a carb adjustment issue and needs to be rectified before using it again, the L jet on the carb is set too lean, if you cannot correct yourself i would suggest taking it to the local chainsaw shop.
Jan 19, 2014 | Husky Garden
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
Hit the throttle it quits running . it starts right up fast idle ok cuts good .wide open throttle runs fine. let it idle and hit the throttle it dies, starts right back up. has new carb kit, fuel, spark...
Conected to the rubber induction boot is the impulse hose, it is a short curled pipe, make sure this has not split and is conected to the two nipples on the carb flange.
Aug 21, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
My bro started messing about with the carb setting screws on his Husky 350 and now the thing won`t start.I tried to set it for him but the limiters aren`t working so I have no idea where the H,L and ide...
run both scrwes all the way in and them back out 2 and 1/2 turns. thats a good starting point. adjust the low while idling and the high with the throttlr wide open.
Jul 11, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Bought a new husky chainsaw a 455 rancher. was told i had to break it in on small logs & not run it very long at first. is this true
The factory usually recommends 2-3 tanks of fuel going easy on the saw and not running at full throttle.......but I have never done this on any of my saws and I don;t know anyone who has and my saws are all still running great.
May 20, 2011 | Garden
I have a series 51 husky saw. it starts and runs normally until it gets up to operating temps. then it stalls out and either refuses to restart or just won't restart until it cools down again....
sounds like air fuel mixture screws are out of adjustment..start with the on marked (L)..this is the low speed(idle) adjustment...turn it in all the way just until it stops..but be gentle..then you wnat to turn it out 1 1/2 turns as a starting point..start the engine and adjust it until you get a smooth idle...next, with the saw running, pull the trigger and you should have a smooth response from slow to fast...you can adjust the (H) screw until you get good high speed operation...if these adjustments don't fix the problem thenm yoou may need to have the carb rebuilt( a carb kit is usually only 15-30 dollars)
May 09, 2011 | Husqvarna Garden
Carb adujustment on a huskavarna 61
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Be sure to have fresh fuel mix in the tank (50:1 ratio) and be sure to shake the container thoroughly just before adding fuel to the tank to prevent oil starvation. Turn both jet screws CW to stops (lightly), then turn each out CCW 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on and adjust H jet needle CW until the engine starts to speed up. Proper adjustment is when the engine will 4-stroke unloaded, but will 2-stroke immediately when cutting. Release the throttle and adjust L jet needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but the chain doesn't try to move. Hope this helps!
Nov 04, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Chain saw carburator settings for husqvarna 61
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Carb assembling question
Thanks Jerry.
The only that came to my mind is to try here:
ArboristSite Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did a quick search and saw nothing for a 61 carb but it does not mean it is not there. Someone at Arborists has rebuilt your carb. The hard part will be digging them out then dredging up the right memories. Good Luck. HTH Lou
Mar 05, 2010 | Husqvarna Chainsaw Piston Kit for 61...
25 yr old Husqvarna 266. starts fine, lots power, but won't idle.
I think you have exceded our level of help. Please try here.
ArboristSite.com Chainsaw thread (free to join)
You might read this thread
http://www.arboristsite.com/showthread.php?t=110858&highlight=husky+266
I searched for "Husky 266" and got many positive hits. She is a respected machine.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9f5525102886abf488256b52001a33af?OpenDocument
HTH
Lou
Oct 16, 2009 | Husqvarna Garden
Garden Logo
60 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
