I have a TechSolutions Model SD-2310 cross-cut shredder that has (after a long time) failed. The problem appears to be that a resistor on the PC board has burned out. Because of its condition, and no labeling on the PC board beyond the designation "R1" there is no way to determine what the resistance and wattage of the replacement should be. Can you point me to a circuit diagram with this information? Thanks
  • 579 Answers
SOURCE: Fellowes Shredmate Cross Cut Shredder
Learn something new every day!
Posted on Dec 31, 2007
  • 17 Answers
SOURCE: paper shredder
The only solution with respect to safety is to order a new switch from the companuy that manufactures/sells this shredder, and mount it according to the manufacturer/sales company's instructions.
If you want to bypass the safety of the machine, just keep the cables (should be 2, + eventually a ground cable) open, or shorted, depending of the machine's configuration. Remember that this is on your or your collegaues own risk!! A shredder can easily bite your finger off!
Posted on Jan 06, 2008
fellowesrep
  • 102 Answers
SOURCE: Kindly help in repair of my Fellowes FS5 shredder
you have a broken or stripped gear
Posted on Feb 22, 2008
  • 280 Answers
SOURCE: Partial horizontal collapse. Nu-tec Model NTT-829A
If you have retrace lines I would recheck all caps around the vertical IC 100@16 is the most common 47@35 and 220@35
Posted on May 30, 2008
JayBlair
  • 328 Answers
SOURCE: when on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
Posted on Jun 05, 2009
No power to shredder, no reset button, reverse will not solve
The motor may have overheated and failed, especially if the shredder was operated at its rated capacity or operated continuously for long periods of time. The specs for these devices tend to be exaggerated.
Apr 22, 2014 | Ativa Hd1600 16-sheet Cross-cut Shredder
On/Auto does not egage
There is often a plastic link to the switch, which can fail.
Check with the maker.
Jan 30, 2014 | IdentityGuard Cross-Cut Shredder
I just bought the Omnitech 10 Sheet Cross Cut Shredder. Is it safe to shred papers with staples in them?
I don't have that model but have an 8 page cheapo shredder. It takes CDs, credit cards and staples with no whining.
Oct 23, 2013 | Omnitech 12 Sheet Cross Cut Shredder
Knocking noise when shredding paper
Cross-cut shredders require monthly oiling of the cutting cylinders to maintain proper operation. Failure to oil the blades regularly could result in excessive noise during operation.
Oiling Your Shredder's Cutting Blades:
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three times.
I hope the above helps....
Good luck.
Apr 13, 2011 | Fellowes DM8C Cross-Cut Shredder
How can I choose between cross cut and strip cut?
DEPENDS ON THE SECURITY OF THE SHREDDED DOCUMENTS YOU WANT.
A MEDICAL OFFICE WOULD NORMALLY HAVE A CROSS-CUT SECURITY SHREDDER SO NO-ONE CAN PUT DOCUMENTS BACK TOGETHER..ALSO BANKS AND LAW FIRMS.
A STRIP CUT SHREDDER CAN BE PUT BACK TOGETHER IF YOU ARE DETERMINED ENOUGH.
Mar 10, 2010 | Office Equipment & Supplies
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Need part for royal shredder model sc800
Here's what I found, but good luck...... I've been on hold for 20 minutes now....
http://www.royalsupplies.com/contact-us.html
Spare Parts: 800-222-2310
Jan 31, 2009 | Royal Office Equipment & Supplies
Need parts for my techsolutions paper printer TS 4500
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 10, 2009 | Winsource Tech Solutions TS-4500 Cross-Cut...
51 people viewed this question
jasbo
jasbo
