Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
GE Profile water pouring from ice maker - GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
  • 415 Answers
Shut off the water to the unit and sounds like either the disp switch is stuck or the water valve faulty.
Posted on Apr 02, 2011
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
I poured water into the icemaker and ice cubes are formed but will not be dumped into the empty tray of my ge profile
The icemaker is bad then . It will have to be replaced by removing 2 screws and a plug connector . Easily replaced . Make sure the icemaker is turned on though .
Aug 16, 2009 | Refrigerators
Ice maker not making ice GE Profile
First check the temp inside the freezer. If it is not colder that 10 degrees the ice maker will not operate. If it's cold enough make sure the water has not been turned off and that you have water coming to the frige. If you do, inspect the tube where water comes into the freezer and pours into the ice try. See if it is frozen closed. If not, disconnect the water line opisite your water supply on the water valve. Using jumper wires, connect 110v to the valve. Water should come out when you attach the 110v. If not or the tube is frozen that you checked before, either one of these will require you to replace the water valve.
Aug 15, 2009 | GE Profile PSI23NCR Side by Side...
My GE Profile Arctica is not making ice and not dispensing water.
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE ice maker has forzen up with too much ice & wont eject
Unplug refrigerator, remove frozen food and use a hair dryer on the ice to remove it. Thanks, Sea Breeze
Feb 08, 2009 | GE Profile Stainless Bottom-Freezer...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
90 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
