Question about Cameras
Samsung Digimax S500. Switch it in and when I go to take a pic is blacks out and will not on/off switch will not retract lens. Sometimes it says it has a low battery before switching off but I have put lots of new batteries in.
  • maybank_paul Nov 13, 2008
    Samsung Digimax S500. Switch it on and when I go to take a pic is blacks out and will not on/off switch will not retract lens. Sometimes it says it has a low battery before switching off but I have put lots of new batteries in.
  • 9 Answers
Sometimes 'new' batteries are not enough - put in a new set of high power *alkaline* batteries and try turning the camera on and off then.
Posted on Nov 26, 2009
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Black screen
The issue is likely a bad lens assembly. Consumers wishing to repair this can check ebay for a replacement lens assembly, motor and sensor are usually included.
This happened to my Samsung s700 while I was mucking with it recently. It can happen when the lens meets severe resistance while trying to open, thus damaging the lens. The camera turns on and cannot tell precisely where the lens is, and subsequently the camera leaves the CCD imaging sensor turned off.
Replacement is easier than repair as lots of intricate parts are involved. However, the centermost ring will pop off with a little force, revealing four screws. The screws on the back side of the lens assembly are pretty obvious. Best of luck to anyone trying to fix this rather than replace it...
Apr 04, 2009 | Samsung Digimax S500 Digital Camera
Cracked LCd Sceen on a Samsung digimax S500
go to dealtree or 2nd turn on ebay and search for your camera with a stuck lens or focus problem the screen is mostly always good. if they say screen gives me an error or anything its good.
Nov 28, 2008 | Samsung Digimax S500 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Digimax S500
The lens stays in the outmost position although batteries are fully charged. This has happend twice. The first time I had a valid waranty so the problem was fixed for free. Now it has happend again and there seems to be no way to get the lens back into the camera. Also the display is totally black.
I guess I have taken about 500 pictures since the last repair. Not very much - even a cheap camera should last for longer than that.
Never Samsung again!!!
May 20, 2008 | Samsung Digimax S500 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
The lense does not close in
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Samsung Digimax S500 Digital Camera
My samsung s500 digimax isd problematic
The Zoom motor is shot probably because it has had a knock or dropped. This is not an economic repair option I feel Check Samsung customer support
Sep 22, 2006 | Samsung Digimax S500 Digital Camera
Cameras Logo
95 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
