Question about Porter Cable VariableSpeed QuikChange Tiger Saw Kit Model 9735
I have a tiger saw 746 with a broken blade in the collar. how can I get to it?
Try taking the boot off and removing the shoe, then maybe you can get at the collar to loosen it?
Posted on Feb 28, 2013
Not much chance I can see of getting the **** thing out of my saw either.
Mebbie I gotta try something else,
Posted on Feb 08, 2012
2 Suggested Answers
  • 2527 Answers
SOURCE: I have a Model 737
Its hot pressed onto the shaft its made not to come apart because if it did in use it would not be good. I use sawalls all of the time and fine if the blade snaps low you can get them out with a strong magnet if you hold it up side down and turn the collar shake it around mabey spray some WD40 in side first it may take a little doing but it beats takeing that change collar a part.
Posted on Jan 14, 2011
How do you install new blades on a DW7332?
unplug the saw/remove battery
press the button on the side near the blade
pull old blade out. push new blade in, release button to lock new blade in place.
Jun 06, 2014 | Saws
Portercable 737 tigersaw can't keep a blade in the quick latch
You can try spraying some lubricant into the blade holder. Sometimes the "ball" in the shaft gets stuck from dirt. Otherwise you will need to disassemble it by removing the roll pin that holds the collar on the shaft.
Mar 08, 2014 | Porter Cable Variable Speed All-Purpose...
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
I have a Model 737 Tiger Saw that was loaned out and now I cannot load a blade. It appears that a blade may have been broken off in the quick change collar. I cannot pry it out, so I must disassemble the...
Jan 14, 2011 | Porter Cable VariableSpeed QuikChange...
Blade keeps falling out when jig saw is started?
ther could be an old peice of a broken blade stuck in the collar were you insert new blade
Oct 07, 2010 | Ridgid 26638 Saw R3121 Orbital Jigsaw
The diamond insert in the hub of the blade keeps falling out as soon as I start a cut. What is wrong?
DO NOT USE SAW!!!
1. switch off saw, remove cord from socket (positive electrical insulation)
2. lift table for maximum cut and check size of the washer holding the blade,
3. you should have holding nut with collar, collar is about 1 1/4 (32mm) diameter, then blade (diamond is actually universal reducing bush in some blades) and lastly you should have internal washer, again, about 1 1/4" (32mm) diameter. if your collar are smaller, you need to replace blade as not suitable for your particular model, albeit I am rather suspicious that you have wrong collared nut and internal collar. Please check if both collars are exactly this same diameter. Please check if collars cover diamond cut-out.
4. if you see discreptancy between description in 3, purchase suitable blade (external diameter is 7 1/4" (184mm), as you did not supply what model of your saw, therefore most probably shank is 5/8" (16mm),
5. mount internal bush (collar), will go correctly only in one way.
6. mount blade (pay attention to cut direction, cutting surface should be clockwise if you look at mounting shaft.
7. mount external flared nut
8. check blade for slippage and wobbliness
9. connect power cord and switch on/off
10. check saw blade againg for slippage/wobbliness
11. make test cut if 10 was correct
12. use normally
Do not forget that this is not a toy, it will cut through wood, ocassional nail and your fingers.
Opearating saw crate flying debris, always wear googles or facemask, you have only two eyes and there is no spares.
Please leave note how you go with this advice.
Aug 18, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
How does one remove a broken blade from a Bosch rs20 blade holder
twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Porter Cable VariableSpeed QuikChange Tiger Saw Kit Model 9735 Logo
174 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
