Question about Malber TD800 Electric Dryer
What is the sun button for? - Malber TD800 Electric Dryer
Howl I adjust the brightness on screen
There should be a menu button on the monitor. Once you press that button depending on your monitor brand, on some there are two button that you can navigate up and down and another button to select. You have to navigate to the menu that have an icon like the sun to adjust the brightness. If you are using a laptop you can simply press Fn + one of the F button on top of the keyboard that have the picture of the sun. See picture for more detail
Jan 21, 2018 | The Computers & Internet
I have a Toshiba harmon/kardon model M35 S320. The screen is not too dark to see anything, but it looks as if it is set on dim...I cannot find a setting for the brightness. what can I do??
On the keyboard should be an fn button usually by the ctrl button.
At the top of the keyboard there should be a button that looks like a sun and has a arrow up or down.
Now combine the fn+the sun button.
Hope this helped.
Aug 27, 2012 | Toshiba Satellite M35-S320 Notebook
I need to how to keep the hood up on the carrycot for the quinny buzz 4
Hi
The sun canopy on the Quinny Dreami is unlocked by grey buttons on either side at the hinge point (where the sun canopy joins the body of the Dreami) both buttons should be pressed and the sun canopy raised or lowered - both buttons then released locks it into position.
If it has been forced the mechanism will be broken and the lock will not function, resulting in the sun canopy not staying in place. The Dreami will require inspection / repair by Quinny engineers.
Please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab on the right side of the screen to be put in touch with the customer care department for your country.
Apr 14, 2012 | Quinny Buzz 4 Jogger Stroller Electric...
I cant avail an internet service with my sun cellular sim using NOKIA C3.
1) To activate your GPRS, text ACTIVATE to 2300.
2) To configure your handset, text SUN GPRS <handset model> to 1200
or to manually change your settings:
Open PC Suite Select Connect to the Internet. Click Settings button Select Modem on the pull-down list Click Next > button Click Select your network operator from the list. Select Select your network operator from the list. SUN Philippines OR Click Configure the connection manually Click Next > button Enter Access point: minternet Leave User name: <None> Leave Password: <Blank> Click Finish button Click Connect
May 01, 2011 | Cell Phones
How to set utilitech wall timer for dusk/dawn settings
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I tried the solution outlined above. I very carefully followed the instructions, but never saw the "sun moon" symbols when pressing "Program" over and over. Any thoughts?
Which timer do you have??
You posted under ST01C timer >> this timer does not have a sun-moon button...
The Utilitec 0192773 timer has a sun-moon button
However the Utilitec 014224 does NOT have a sun-moon button
There are a lot of timers on the market, and each has different instructions
The following page may help you identify your timer
The page has manuals for many of the timers shown
http://waterheatertimer.org/Programmable.html
Answer this response, or re-post another question after you identify timer and get the correct manual
Oct 21, 2010 | Intermatic Inc. ST01C Digital In-Wall...
THE LAPTOP WORKS FINE BUT THE SCREEN IS VERY DARK
Every laptop that is coming to the market has a button the bottom left just next to the "Crtl" button. This button says "Fn". On the other hand please find the buttons that are marked with dark Sun or a white sun. These buttons are for decreasing or increasing brightness. Just press down the "Fn" key (or button) and then press the key with the white sun on it. The brightness of the laptop screen will increase.
The keys with sun symbol on it are usually the arrow keys.
Good Luck!
Aug 04, 2010 | Toshiba Tecra 8200 Notebook
How do I program the garage door opener on the sun visor?
Directions are in your owners manual. Most are done by holding down the sun visors button until it flashes, then hold your opener next to the visor and push your openers button.
Sep 22, 2009 | 2000 Volvo S70
Where to get a maxi cosi sun canopy from?
hi if the car seat you have is the cabriofix it already has sun shade, if you look on the back there is a button under the rim at the top ( on mine the button is silver ) hope this is helpful
Mar 29, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Malber TD800 Electric Dryer Logo
55 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Tim Whalen
Are you a Malber Dryer Expert? Answer questions, earn points and help others
