Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I have borrowed a bissell proheat 2x from a friend and she did not have a manual. I cannot get the brushes to turn.
    Genius:
  • 1,739 Answers
The User Guide for the Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner is available here:
http://canada.bissell.com/images/UserGuides/9500_107.pdf
Note that the brushes only turn when the unit is reclined using the detent pedal.
If machine has been jammed the internal circuit breaker may have been tripped. Unplug machine from power source, remove object or blockage and then plug machine back in to power source to reset breaker.
More seriously the drive belts may have become worn or have broke or a brush may have become detached; refer to page 18 for instructions on how to replace belts and brush rolls.
More information including a video and replacement parts can be found here by selecting the tabs across the screen below the picture of the machine.
http://canada.bissell.com/Products/p/9500/ak/more+info/Product.aspx
Posted on Apr 02, 2011
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat 2x troubleshooting
Hi, it's Allie from Crucial Vacuum!
There are several things that may cause this to happen in your Bissell ProHeat 2x, like the brush assembly or the belts.
First, make sure the cleaner is reclined, or the brushes will not turn. If your unit is reclined and the brushes still do not run, check if there is anything tangled in your unit's brushes or if the brushes are damaged. Clear the brushes of any hair strands or tangled debris for their optimum performance. We recommend for these brushes to be cleaned and checked monthly and replaced once a year.
Next, unplug your unit and check both of your units belts. It is recommended for belts to be changed every 3 to 6 months, depending on the use of your unit. Belts can be stretched out and loose, causing the brushes not to spin properly.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 15, 2014 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell proheat 2x pet won't spray water or **** dirty water up
A belt may have broken, there are two which drive the rollers. Remove tank, turn over and have a look behind the brushes. Check the manual for how to find and replace.
Feb 13, 2011 | Bissell ProHeat 2X CleanShot Bagged...
Bissell proheat select 2x brushes have stopped turning
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
kjjk
Jun 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
The brushes on my Bissell Proheat 2x shampooer won't turn.
You need to replace the belts on the roller brush. Here are the belts you need:
Bissell Proheat 2X Belts
May 24, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No Manual
I need a manual for the bissell proheat 2x 9200 carpet cleaner.
Nov 17, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x
Check the brush motor, I have had to replace of few of them. If the brushes aren't turning, this could be the problem.
Apr 18, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
490 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
