Question about Home
I lost the install instructions for my Moen 270 exact temp shower kit.
    Genius:
  • 1,739 Answers
Moen Chrome ExactTemp Vertical Spa:
http://www.moen.com/moen/chrome-exacttemp-r-vertical-spa/_/R-CONSUMER%3ATS270
Product Specifications:
http://www.moen.com/shared/pdf/ts270sp.pdf
Exploded Parts View:
http://www.moen.com/shared/pdf/ts270pt.pdf
Replacement Parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=TS270
Unfortunately the installation Instruction Sheets/Owner's Manual are not posted for the 270 models. Suggest you contact Moen Consumer Support directly to make a request:
http://www.moen.com/consumer-support/contact-us
Posted on Apr 02, 2011
My Moen exacttemp thermostatic shower goes to either hot or cold - can't figure out how to control the temp. This was just installed and the installer didn't provide instructions.
Your meon shower has a carriage the handle is attached to, sounds like there might be something in it or the carriages is warn and needs replacing.
Apr 17, 2011 | Moen TL3450/3600/3371 Kingsley Handle Tub...
Moen Shower Valve Model L82839 installed: Water comes out of shower head when running bath. Thanks.
Only two possibilities here the diverter tub spout is not open all the way to let water to the tub only or the shower valve is installed up-side-down.
http://www.moen.com/shared/pdf/l82691pt.pdf
Mar 06, 2011 | Moen & Posi-Temp Single Handle Shower Or...
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Water temp. regulate
Moen faucets have only one moving part. The stem slides up and down to open and close the faucet and rotates to regulate the flow of hot and cold water. Any leaking requires replacement of the cartridge.
First, turn off the water. To remove the cartridge, you'll need to remove the handle. This project can be like working a puzzle. If you have the manufacturer's instruction sheet for the faucet, you're ahead of the game. Without it, look for a retainer clip at the rear of the faucet just below the handle. Or, you may have to remove a set screw or snap-in "hot-cold" button and a handle pin or screw. On some faucets the swing spout must come off first. The retainer clip may be hiding beneath the handle inside a lift-out tube. Some cartridge faucets use two retainer clips–one by the handle and another by the cartridge. Retainer clips can be pried out with a screwdriver.
Once the retainer clip is removed, the cartridge simply pulls out. Use pliers, as shown in Fig. 6. Install the new cartridge by pushing it into place with the flat arrow, or other mark upward. If you use a lubricant on the cartridge, make sure it's silicone grease.
Check and clean the cartridge inlet ports. Before you button up the faucet turn the water back on for a minute to flush out the supplies. I had to look for this answer, hopefully this will work for you.
Jul 21, 2010 | Moen & One Handle Tub & Shower Faucet
My Moen shower valve didn't come with any installation instructions. do you use the plastic piece that is attached to the valve or is it just to protect the valve for shipping? it is only attached with one...
it is used for keeping the valve from coming thru the big hole when you tighten up the main cover,...it's to go on the back of the shower wall,..you don't have to use it if your valve is secured enough via pipe clamps and/or the like. good luck
Jan 02, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
1,168 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
