Question about Spar SP-60PZ Commercial Planetary Stand Mixer
No power cable desconectio - Spar SP-60PZ Commercial Planetary Stand Mixer
    Genius:
  • 1,157 Answers
Hi luismoral,
May I ask if your machine won't turn on?
Thank you for using FixYa.
Posted on Apr 02, 2011
My kMix kmx50 stand mixer trips the power to when I put the head down
The problem may be the wiring /cables from the base unit that runs up inside the machine to the motor has got damaged and is shorting out against the casing or shorting out between cables
especially at the hinge point , you will need to gain access to inner wiring/ to repair, good luck PS it may only need a bit of insulation tape around cables , good luck
Nov 15, 2016 | Food Mixers
How to replace power cord?
Replacing a power cord is fairly straightforward for those who already have a little experience.
The power cord is either obtained as an assembly as a spare part for your machine or bought as a simple length of cable from the local hardware or electrical shop. If the strain relief grommet is moulded onto the cable an assembly will probably be needed.
Carefully removing the existing lead will provide a pattern with the correct dimensions to cut the replacement, remove the insulation, etc.
Appliances use a variety of methods of connecting the power cord into the internal terminal block but which screws to remove is usually an intuitive process.
Jan 23, 2016 | Food Mixers
How to fix a Kitchenaid Professional HD Stand Mixer?
Remove the top cover, screws are under the metal trim band with the writing on it. Get a multi meter and follow the power. Where the power stops is a good place to start looking. I think the electric internals consist of a PCB complete and a motor complete. If the motor has a circuit and both field windings are even resistance then you are probably looking at a pcb replacement unless you are an electronics whizz. There may also be an interference suppressor across the mains power supply in some countries, unlikely that will stop it though. Certainly look for any unplugged or broken connections inside from mains cable to pcb.
Feb 04, 2015 | KitchenAid Professional Hd Stand Mixer...
I have a hl200 mixer that wont start. What do I check
The power supply, like mains, plug and cable. then the on of switch or button. To check the motor, you have to open it, but I think you better leave that to a tech.
Jan 23, 2015 | Food Mixers
Where is the jenn air mixer thermal cut out
Wonder if you checked the user manual on possible causes for not turning on. see page 10.
http://content.abt.com/documents/5384/JennAir-Mixer
Aug 13, 2014 | Jenn-Air Attrezzi JSM900 Stand Mixer
Artisan 5KSM150
Remove the back cover and run it LOOK BUT DON'T TOUCH. Are the copper contacts jumping when the speed pulses? If yes you will need to SLIGHTLY twist the copper contact bar so that only one of the pointed contacts touches at low speed. Your adjustments will be done with the power cable unplugged.
Nov 20, 2013 | KitchenAid Food Mixers
No power
Check for broken wires around the black speed control assembly under the back cover. Check carbon brushes, THEY ONLY FIT ONE WAY. Check cable for continuity.
Jun 24, 2013 | KitchenAid Food Mixers
Have a PVi8B mixer that has stopped working suddenly. Doesn't do anything when you flip the switch to "ON" are there fuses that could be the problem?
Does the blue power light come on when you switch it on? There is a 5amp fuse in the supply cable.Open the wall socket plug of the supply cable (unplugged of coarse) and check fuse and connections.With a multimeter check continuity of the three wires from the plug to the other end of the cable.If this is all good then you have an internal fault.There are fuses internally as well but this should be refered to a qualified technician.
May 10, 2013 | Food Mixers
Kenwood KM300. How to fit new mains cable ?
Having done it the hard way (!) it is dead easy. All you need is a small screwdriver or similar, approx 2mm by 1mm in cross section. Looking from outside the mixer, where the power lead enters the main body, between the rectangular lead casing and the socket it enters, there is a small rectangular cutout (top right). Push your screwdriver in around 15mm, and then withdraw the lead housing with it - the screwdriver pushes the latch aside, hence you need to remove both as one! With luck, and a wiggle or two, that should be it.
Mar 10, 2013 | Kenwood KM300 Chef Stand Mixer
How can I replace a damaged power cord on my KitchenAid stand mixer, Model #K45?
Firstly get a new cord. Then remove the trim plate and then the end cover. Remove the rubber grommet and then the three cables from the clips. Replace with new cord.
Feb 13, 2010 | KitchenAid K45SS Classic Stand Mixer
Spar SP-60PZ Commercial Planetary Stand Mixer Logo
24 people viewed this question
Top Spar Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Spar Food Mixer Expert? Answer questions, earn points and help others
