Question about Ovens
Hot point gas oven - Ovens
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman10
Posted on Apr 02, 2011
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
Hot point range - model #RG85080PA1WH
Your oven igniter has gone bad, even though it still glows, they just wear out and don't open the gas valve to ignite the gas.
Here is the one for your model:
Part#WB13K21 (http://www.repairclinic.com/referral.asp?R=1265&N=2494)
http://www.repairclinic.com/dbimages/00000578/00175428.jpgOven igniter assembly (http://www.repairclinic.com/referral.asp?R=1265&N=2494)
Jun 18, 2008 | Hotpoint SY36 Style Line Stainless Steel...
How to replace a thermocouple on my hot point gas oven
There should be an wire going into the insulation .Isolate the wire ends and use DMM to check that the thermocouple is working properly.It should have some resistance.If it says OL then remove gently and replace with same new part.
Thanks
Please rate my Work.
Sep 17, 2011 | Ovens
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
VDGO viking gas oven upper won't heat
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
How do I light the oven on a gas stove
If this is a newer stove (that does not have a pilot light...and most newer stoves don't), you shouldn't have to light the oven manually (if you think you need to, you have a faulty stove). Manual ignition of a stove is also potentially dangerous as larger amounts of gas in the oven can cause small explosions. Most modern gas stoves use a very hot glowbar to both regulate the amount of gas entering the oven and igniting that gas. If you have a faulty glowbar, it will not allow enough gas to enter the oven and may not be hot enough to ignite the little gas that does enter (that is why you may smell gas). It sound like you may need to replace the glowbar (or visually inspect the glowbar to see if it gets red hot. If it does, it may still be faulty (not drawing enough power). The only way to test this is to use a clamp-on ampmeter and test the current flow through the wires feeding the glowbar. They should read between 3.1 and 3.7 amps. Anything lower means the glowbar should be replace. If you cannot see the glowbar get red hot, you have an electrical problem or a circuit board problem.
Jul 11, 2009 | Maytag CWG3600A Gas Single Oven
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
DOOR LOCK WONT OPEN
do both of you have a digital display? if so are you getting any codes that f- with a number?
Nov 20, 2007 | GE JGRP17 Gas Single Oven
Hot point beeper wont stop
This is a code for an over temp condition.
If the oven is cool then there is a problem in the sensor circuit, usually a failed temp sensor.
Post back if you have any questions.
Nov 18, 2007 | Hotpoint SY21 Style Line Gas Single Oven
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
