Question about Hotpoint VBXR1090B Top Load Washer
Very noisy spin cycle - Hotpoint VBXR1090B Top Load Washer
  • 415 Answers
Not a good sign, do you see any water under the washer after a load is completed. How do you tell when empty tilt it back a ways and check it, if it does it could be a leaking tub seal and a replacement may soon be in order. Unless you overhaul it.
Posted on Apr 02, 2011
Noisy spin cycle
IT SOUND LIKE YOUR REAR BEARING IT GOING OUT ON THE WASHER
Nov 02, 2012 | Kenmore Washing Machines
What does F7 mean, why has it become very noisy on spin cycle and leaks occasionally?
THAT MEANS IT REQUIRE ANEW BEARINGS AND OILSEAL......THAT MEANS U NEED A SPECIALIST TO REPLACE THEM.
Feb 24, 2012 | Washing Machines
Noisy on spin cycle "rattling"
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Very noisy during spin cycle
The drum balance ring cound be unliquified. Turn it when it is off. There should be sloshing. If there isn't, call in a repair man. He will try to fix it.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Noisy spin cycle
It would be noisier than normal if it was not level.
Best way to tell if it is noisier than normal is to spin the drum by hand, there should be little or no noise from it.
If it is noisy or rumbling, or feels rough, then I would suspect that the drum bearings are worn and noisy.
An hour to complete a wash cycle is not abnormal, and they do do several rinses.
Plz rate my solution.
Thanks.
Dec 26, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Hotpoint VBXR1090B Top Load Washer Logo
52 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
