Question about Zyxel Prestige 941 (AM409300) Bridge
Cant connect into internet, and Vista diagnostics gives following message: Windows confirmed that "primary DNS Server" is currently online, but is not responding to connection attempts at this time. This usually means that a firewall is running somewhere between two computers and is blocking "domain". Windows has confirmed that Windows firewall on this computer is correctly configured to allow this connection. However, a remote firewall might be blocking your connection. The following policy might need to be adjusted to allow windows to connect: Policy provides: Windows firewall Filter name: Query user If the policy provider identified is windows firewall, click for information about adjusting windows firewall settings. If a different policy provider has been identified, check the providers documentation on how to adjust the policy settings.
5 Suggested Answers
SOURCE: Can't Open Internet Explorer
You have to contact your service provider. That's a thing which is done by them to secure there internet service. They will give you the username and password. I evn tried that and they asked me to type the modem name and 'admin' as a password. For example, my modem is STstarcom. so the username wax starcom and password: admin.
Thank you.
Posted on Sep 12, 2008
SOURCE: connection problem
hello! i will be more than glad to assist u.. first things 1st. check the type of modem do u use a, are using a cable model from a cable isp provider, dsl model or model router.. If u are using a cable modem from ur cable isp.. u need to mac clone the network interface card of your computer.. if you are using a dsl provide- it could be a pppoe or static ip addressinf, if pppoe u need to setup the username and password given to u by ur isp provider to the router or if its a static ip u need to check the ip address of you computer if its connected directly to the modem, how to check- click on start and then run, type incmd and it will give u the dos prompt, from there type ipconfig/all and it will give u all the details like ip address, subnetmask, gateway, dns server and u need to input it to the router on static ip addressing... i hope this will help..
Posted on Aug 08, 2009
Macs R We
  • 481 Answers
SOURCE: I currently am using a Zyxel G 220v 3 wireless
I'm NOT a Windows guru, but I think this is an issue with Windows, not your Zyxel driver.
There is a setting somewhere in the network area of Windows that tells it to automatically connect to a known favorite network if that network appears. I suspect you just have to find that setting, turn it on, and make sure the network you use is in your list of favorites.
Posted on Jul 14, 2010
puertobori
  • 7733 Answers
SOURCE: configuration utility will not load with windows
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Jan 18, 2011
I CANT ACCESS A FEW SPECIFIC SITES.
Hi Pauline,
Try different using a different DNS address. OpenDNS provides free, fast servers that are used by millions. Here's how to do it with and without a router in your set up:
WITHOUT A ROUTER:
Mac OS X
  1. Go to System Preferences.
  2. Click on Network.
  3. Select the first connection in your list and click Advanced.
  4. Select the DNS tab and add 208.67.222.222 and 208.67.220.220 to the list of DNS servers.
  5. Click OK
Windows 7
  1. Click the Start Orb, then select Control Panel.
  2. Click on Network and Sharing Center.
  3. Click on your primary connection or Local Area Connection under Active Networks.
  4. Click the Properties button.
    Windows 7 may prompt you for permission to make network setting changes.
  5. Highlight 'Internet Protocol Version 4' and click Properties.
  6. Click the radio button 'Use the following DNS server addresses:' and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK button, then the Close button, then Close again. Finally, close the Network and Sharing Center window.
    At this point, we highly suggest that you flush your DNS resolver cache and web browser caches to ensure that your new configuration settings take effect.
Windows XP
  1. Select Control Panel from the Start menu.
  2. Click Network Connections from the Control Panel choices.
  3. Choose your connection from the Network Connections window.
    If you have more than one, choose your default/current connection.
  4. Click Properties button.
  5. Select Internet Protocol (TCP/IP) and click Properties.
  6. Click the radio button Use the following DNS server addresses and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK
Windows Vista
  2. Click on View network status and tasks.
  3. Click on View status.
  5. Vista may ask for your permission to make changes. If so, click the Continue button.
  6. Select Internet Protocol Version 4 (TCP/IPv4), then click the Properties button.
  7. Click the radio button "Use the following DNS server addresses:" and type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in the Preferred DNS server and Alternate DNS server fields.
  8. Click the OK button, then the Close button, and the Close button again. Close the Network and Sharing Center window.
WITH A ROUTER:
Generic Router
  1. Open the preferences for your router. Often, the preferences are set in your web browser, via a URL with numbers (example: http://192.168.0.1). You may need a password.
    If you're like us, and you set the router password long ago and cannot remember it now, you can often reset the password to the manufacturer default by pressing a button on the router itself.
    Or preferences may be set via specific application for your router, which you installed on your computer when you added the router.
  2. Find the DNS server settings.
    Scan for the letters DNS next to a field which allows two or three sets of numbers, each broken into four groups of one to three numbers.
  3. Put in the OpenDNS server addresses, 208.67.222.222 and 208.67.220.220, as your DNS server settings and save/apply.
Linksys Router
  1. Visit the router's IP address in a new browser window.
    http://192.168.1.1 is the default Linksys router IP address.
  2. Enter the Network password.
    The "Enter Network Password" window will appear. Skip user name and type the router's password (admin is the default password, if you haven't changed it) and click the OK button.
  3. Type in OpenDNS addresses, 208.67.222.222, 208.67.220.220, in Static DNS 1 and Static DNS 2 fields.
  4. Click Save Settings button.
Netgear Router
  1. Type the router's setup URL (http://www.routerlogin.net, http://192.168.0.1 or http://192.168.1.1) into a web browser address bar.
    http://192.168.1.1 is the default Netgear router IP address.
  2. Enter the password.
  3. Type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS and Secondary DNS fields.
  4. Click Apply button.
  5. Wait for the settings to be updated.
D-Link Router
  1. Visit the router's IP address (http://192.168.0.1) in a new browser window.
    If you are attempting to configure a D-Link router, take note of your computer's Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. Most D-Link devices use the 192.168.0.X range.
  2. Enter the router password.
    Note: if you have not changed the original settings, the default username is admin and the password is blank (nothing).
  3. Click on the Manual Internet Connection Setup button at the bottom.
  4. Enter the OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS Server and Secondary DNS Server fields.
  5. Click Save Settings button at the top.
Oct 07, 2014 | Computers & Internet
I cannot load to my epcc.mylabsplus.com
I could & I arrived here "Welcome to Pearson MyLabsPlus", which is a gateway to "El Paso college". (IP address 159.182.164.119). Normally I'd just give you the url using the IP address but it wont work as its a secured link.
My guess is that either your browser is damaged (by malware which is redirecting you though an alternate gateway which doesn't have the DNS record) or your ISP's dns simply doesn't know this URL.
24162751-wxpaklkqiapao3rwyzi1syb2-4-0.jpg Does the same thing happen if you use a different browser like Chrome for instance?
Try to reset internet explorer.
To reset Internet Explorer settings
  1. Close all Internet Explorer and Windows Explorer windows that are currently open.
  2. Reopen Internet Explorer.
  3. Click the Tools button, and then click Internet options.
  4. Click the Advanced tab, and then click Reset. ...
  5. In the Reset Internet Explorer Settings dialog box, click Reset.
Network faults
Temporarily change your DNS settings.
  1. Open Network Connections by clicking the Start button , and then clicking Control Panel. In the search box, type adapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties.
24162751-wxpaklkqiapao3rwyzi1syb2-4-2.jpg 4.Now look at the bottom of the screen you will see preferred DNS press the "Use the following DNS server address" and in the first preferred enter 8.8.8.8 and the second enter 8.8.4.4
This is the IP address of the Google DNS servers which will replace your ISP's one. I have tested Google and it knows your El Paso college gateway IP.
Once you have done that OK it and either do a START>RUN>CMD>ipconfig /renew
or reboot the computer.
Try this fix and if it works you can safely leave the settings as is. It wont make any difference to you normal browsing. If not just re access the settings and click the obtain DNS server automatically.
Apr 17, 2014 | Mozilla Firefox
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
NOT RESPONDING TO INTERNET
Let's try setting a static DNS server and see if that takes care of it:
1. Click on Start, choose Run, type in ncpa.cpl and press Enter to open Network connections window.
2. In the Network Connections window right click on Local Area Connection and then select properties.
3. Click Internet Protocol (TCP/IP) and then the Properties button in Local Area Connection Properties.
4. Choose Use the following DNS server addresses: and type in 4.2.2.1 for your Primary DNS (you can leave the Alternate DNS blank).
5. Choose OK/Close to the windows and test Internet Explorer
Let me know if that helps
Thanks & Regards
Anas K A
Apr 25, 2011 | Computers & Internet
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
I have been tring to connect to wireless internet all day with my ps3 and it ethier says my WPA key may be incorrect or errorhas occurred (8013013D)
that is not a problem and i will be glad to assist you. If this doesnt work please follow up with a comment and i can give you instructions on what to do next.
This error code is caused by a connection time out when attempting to connect to the Domain Name Server (DNS). If you are seeing this code you should check the following: • Do you have a working internet connection (can you connect successfully using a PC)? • Reconfigure your network settings (delete existing settings and create new ones) • Does your Internet Service Provider (ISP) prohibit access to secure pages as a default setting? (this may lead to failures when accessing system software updates) • Within network settings, is the Primary DNS being detected? If the ‘Primary DNS’ is displayed as 0.0.0.0 or is blank, the DNS is not being detected automatically. If this is the case you should contact your ISP and ask for the ISP’s DNS address. This DNS address should then be manually input into your network settings. Following all of these steps your PS3 should now be able to get online.
to find your dns in windows > Start
> Run
> command
> ipconfig /all
Then the DNS Server(s) being at the bottom
If it still doesnt work let me know your router model number. Also ensure your WPA key is correct and that its not wpa2 as depending on the model most playstation 3's cant use wpa2. that way if you provide me with your router i can ensure that everything will work with each other and determine the best security settings to get your computer online
If you need further assistance or help with anything please let me know and i will be glad to guide you through any assistance you may need.
Aug 28, 2010 | Sony Playstation 3 (PS3) Console
Cannot access server dns error occuring with internet explorer 6.0
make sure your dns setting is correct follow this :In the Windows Control Panel, >go to Network Connections.> Open 'Local
Area Connection' and select 'properties'.
Doubleclick on Internet Protocol (TCP/IP)
check or Select 'Use the following DNS servers'. Put the correct dns address in the primary
address window. Leave the alternate blank. Close all the Windows. Try
browsing again
Sep 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
DNS Event Id 7062
it sounds like you have 2 DNS servers running on your network.
disable the one in windows and use the one supplied by your router
Mar 04, 2008 | Microsoft Windows 2000 for PC
Zyxel Prestige 941 (AM409300) Bridge Logo
156 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
