Question about Carrier Heating & Cooling
Carrier model KCA012101P i BOUGH IT FOUR MONTH AGO . IT WAS WORKING PROPERLY AND THE RESTARTED IT AFTER 2 HOURS . AND IT DIDN'T START .THE CONNECTION IS OK WHAT DO YOU THINK IS THE PROBLEM ? MUSTAFA EMAIL [email protected]
SOURCE:
  • 5 Answers
SOURCE: Connection Problems
If you have other Optical Drive in your computer like a CDwriter then installed it where that LG 52x CDROM drive. Observe if the same problem occur after 2 or 3 hours. Try connecting the CDROM drive to the IDE ports (Secondary IDE port) like setting its jumper to Master. Ensure that the connection to its power supply is firm. Change the setting of your POWER OPTIONS which is under the CONTROL PANEL and change the setting for TURN-OFF HARD DISK to NEVER.
Posted on Apr 09, 2007
docjohn174
  • 943 Answers
SOURCE: won't spin all other functions work properly
hi thanks for the question the washer does not spin to pump the water out first it has to pump the water out in your case i would check the drain hose make sure theres no obstruction thanks the appliance doc
Posted on Sep 26, 2008
  • 4 Answers
SOURCE: During scheduled recording for 1 1/2 hours, chanell changes
I called panasonic and they sent me @ no charge a cd update that fixed my problem. I talked to
John @ 1-800-211-7262 ext 5070. He seemed very knowledgeable and spoke ENGLISH!
This cd may fix other problems for this model.
Posted on Jan 10, 2009
dlundmark
  • 797 Answers
SOURCE: My camera did not flash properly
All of these little point and shoot cameras work the same way.
Go to the menus reset all to default.
check the camera again...see what happens.
If it does not work right yet.... repair is probably needed. However the cost of repair is maybe more than it is worth.
Make sure the battery or batteries are up and new.
You may be able to sell on a site such as Ebay for parts or repair, if you cannot fix it.
To repair is complicated, and takes a good amount of time.
May be loose cable or cables inside the camera or some part is dead or broken.
Posted on Sep 09, 2009
Jahn27
  • 1554 Answers
SOURCE: when we hit the start button on our feq1442es1, it
The problem is most likely the door switch or the thermal limiter (non-resettable thermal fuse) mounted to the rear of the heating element. The door switch and the thermal limiter are wired in series with the motor. Power to the motor is cut when the door is open, the door is switch is bad, and/or the thermal limiter is blown open hence the dryer will not start and no dryer function works.
Check the continuity of the thermal limiter and if it reads open, it must be replaced along with the high-limit thermostat which must have cause the limiter to blow. You may bypass the thermal limiter, for troubleshooting purposes only, by putting a jumper wire across its terminals. The dryer should run and if it doesn't, either the door switch,
the motor, or the electronic control has failed. Bypass the door switch by jumping a wires across the COM and NO terminals and if still doesn't run, check the continuity between the terminals M4 and M5 (windings) of the motor. The control board is faulty if the motor windings has continuity, else replace the motor.
Regarding the drying problem, make sure the lint filter is clean and the vent system is not restricted. Replace the control thermistor located on the blower housing.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jun 27, 2011
Stalls losing electric power
How old is the battery & have you tested it?
How is it that a month went by & your using
any vehicle that could let you down?
Why have all issues not been resolved ,as soon
as they started?
Have you checked for codes?
Have you had a professional scan tool on it
& checked data,that has to be done along with
many other checks or tests,unless it's just a battery
issue.
No one can solve any vehicle issue over the internet
There is always more to the story & you need the patient
Jul 19, 2013 | 2004 GMC Envoy
2000 Dodge Stratus SE stalling and not restarting
Sounds like a broken wire probably close to where the computer is. I would inspect the harness here and then under and around the power distribution module (fuse and relay box under the hood) This can be removed for closer inspection of the contacts underneath.
Check all sensor connections especially the crank
Pull the MAP sensor plug connector out and try to start the car, if it starts and runs rough and then wont when the map is plugged in then replace it and you are a go.
I think this is your problem or fuel pump or the fuel pump wire is corroded typically where it connects to the harness and then goes into the body.
This is somewhere to start at least.
Sep 23, 2012 | Dodge Cars & Trucks
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I HAVE MOTOROLA(MOTO W233,NOT RENEW).I BOUGHT IT 2 YEARS AGO.IT WAS FINE THAN.LAST YEAR I WENT HOME- OVERSEAS, AND STAYED- FOR 6 MONTHS.ONCE , I COME TO CANADA- MY CLOCK (NOT ALARM IS 1 HOUR EARLY. CAN...
Now the numbers change depending on your cell phone carrier, however there should be a three digit number that updates your phone, connects it to local cell towers and gets it up to date. Should update your software, clocks, and service. Typically it's 611, but once agan it varies for each carrier. Just ask your provider what the number is, dial it, and your phone will update.
Mar 08, 2011 | Motorola Cell Phones
MY CAR'S AIR CONDITIONING ISN'T WORKING. MY SON
mcdevito75 here, either your son in law didn"t put in enough freon or the compressor is not working, Have your local shop check it out.
Jun 18, 2010 | 1998 Cadillac DeVille
Wireless lan not working
Try to do a system restore back to the time it was working.
Sep 23, 2009 | Acer Aspire One PC Notebook
Heating & Cooling Logo
271 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
