Question about Alps MD 1000 Thermal Printer
My Alps MD-1000 is not feeding paper. The tray will move forward and i can see the wheels roll but the paper is not being fed into the printer. I tried doing a self print test (disconnected from a cpu) and it tries to feed a few times then the error light and power light blink simultaneously.
  • 83 Answers
Here are a couple of suggestions: Try taking the cover off the printer and check for dust near the paper sensor. While you have the cover removed, give it a good spray with a can of air. Be careful, not to break any parts or to pull out wires. Or you can try setting the paper option in the driver to the thick paper. This sometimes helps when I have a paper feed problem.
Posted on Apr 05, 2011
Roller
If nothing happens no carrier movementor paper feed you probably have a bad keyboard.
If the carrier moves but no feed the index motot may need to be lubed.
If the roll moves but the paper dosen't you may have debris on the paper tray or bad lower fed rolls.
DickyO
May 03, 2013 | Lexmark Wheelwriter 1000 Typewriter
My alps 1000 will not pick up cartrage, head goes back and forth, paper feeds, then goest into error mode
Try cleaning the cartridge carrier sensor. This tells the carrier where to stop to pick up the differnt cartridges They can get dusty with time which can cause a failure.
Nov 19, 2010 | Alps MD 1000 Thermal Printer
How to remove cover off Alps md 1000 printer -
Remove the 4 screws holding the main feed tray. Then GENTLY pry the tabs on both edges of the printer. They are really tight! The fit is great but once you break the "seal" so to say the whole cover just pops off.
Feb 09, 2009 | Alps MD 1000 Thermal Printer
Problem Printing with Alps MD-1000
Have you ininstall the device and reinstall it? Do you have any pending print job?
Apr 22, 2008 | Alps MD 1000 Thermal Printer
Alps md 5000
Hello! can you help me please? My ALPS 5000 printer has been setting for about 3 yrs, I just install it in another computer but the paper will not feed in the printer, It's almost like something in there, but it's not.
Thank's
Jan 27, 2008 | Alps MD 5000 Thermal Printer
ALPS MD1000 Won't print
Please ignore courtdate & creamgetmonE. Here's why:
creamgetmonE - If you're using the XP driver, you are using something so crippled, it should have been aborted. USE THE ALPS DRIVER!!!!!!!!
courtdate, oiling the carriage rail will not change a thing, apart from gunking up the printer, and ENSURING it will fail sometime in the future.
TO FIX YOUR PROBLEM:
There is a sensor under the anti-curl veil. Clean it.
Jan 18, 2008 | Alps MD 1000 Thermal Printer
RECYCLING of ALPS MD-1000 Color Printer
You can buy OKI MD 5000 Cartridges or Citizen Printiva Cartridges. Are the same.
There are also resellers that sells only ribbons to exchange in cartridges. http://www.refillx.com/
Dec 16, 2007 | Alps MD 1000 Thermal Printer
Alps MD 1000 self tests okay, but printing gives "nonvolatile error" (fast blink)
This is a symptom of the following:
You are running XP, and have installed SP3 and, you are using the microsoft driver bundled with XP.
The solution:
The m$ driver will have created a printer with "(MS)" as a suffix. Leave this intact, as it will cause major trouble on every reboot if you delete it.
Download the appropriate driver from the Files section in the Alps YahooGroup found at http://tech.groups.yahoo.com/group/Alps/
With your printer unplugged, install the downloaded driver
Shut down your computer and hook up the printer
Reboot
XP will detect the printer, and create a new printer in Control Panel without the "(MS)" suffix
Make the new printer your default printer.
The reason why you do not delete the printer with the "(MS)" suffix, is because every time you reboot, XP will ignore the fact that you have the correct Alps driver loaded, and will create a new printer using the m$ drivers, and set it to default. Of course, the m$ Alps driver is fundamentally broken
Nov 08, 2007 | Alps MD 1000 Thermal Printer
Alps MD 1000 Thermal Printer Logo
108 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
