Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
The beater bar will not rotate - Dyson DC07 Bagless Upright Cyclonic Vacuum
5 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: My Dyson 07 beater bar doesn't rotate
Hi.
If your Dc07 is all floors it will have A clutch fitted this is easy to determine just stand in front of your machine look down at the left hand side there will be a coloured knob on the side e.g. blue.yellow,green,purple this will have a pointer on it which when you pull handle back to vacuum must move to drive position you can rotate it by hand if it is stuck in park position ,
If there is no belts broken the brushes will now turn.
If they don’t the chances are one of the 2 belts have snapped.
You will then need Manuals to help you repair the problem.
Go to this site for more infomation.
http://dysonmanuals.llc.nu/
Chris..
Posted on Feb 12, 2008
blueextc3221
  • 15935 Answers
SOURCE: The beater bar/brushes are not rotating.
There is an on/off switch RIGHT NEXT TO THE MAIN ON OFF for JUST the beater bar. It is not highlighted in the manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 09, 2009
seanpwright
  • 2030 Answers
SOURCE: The beater bar is not rotating.
You need to replace the belt that drives the beater bar
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Feb 09, 2010
  • 10 Answers
SOURCE: DC15 - beater bar is not rotating
There is a tiny motor for the bar itself at the side of the bar you will see tiny slits which is the vent for the motor which is most likely burned out and will need a replacement.
Posted on Apr 11, 2010
The beater bar in my machine will not rotate just makes a squealing noise
It could be that the bearings in the beater bar are shot or are full of dirt or pet hair. A new beater bar will fix the problem.
Dec 25, 2017 | Vacuums
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Apr 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar not rotating
Remove the screws from the bottom of the power head.
Oct 09, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Change belt on a eureka
With the vacuum unplugged, turn the machine beater side uo. On the plate that surrounds the beater bar, look for release tabs to open the plate. Flip them and set the plate to the side. The beater bar rides in sockets. Remove the bar, install the new belt around the motor shaft, then work the beater back into the sockets. Replace the plate. Test your work by rotating the beater bar by hand, making sure that it is reinstalled correctly.
Best Regards, --WoobieDog--
Jul 10, 2009 | Eureka Vacuums
There is suction but no rotation of beater bar
replace the drive belt.
turn the vacuum over. take the buttom plate off, you can access the roller (beater). there should be a belt attached to the roller and the motor shaft.
Apr 14, 2009 | Vacuums
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
137 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
