Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
C2424 New Printhead & Electronic Module?????
I have a Xerox WorkCentre C2424 with a fault code of 37,004.40:70188.
The scanner light top & bottom stays on all the time. It is almost 3 years old & my maintenance contract ran out 6 months ago. )o;
I am very good with electronics & someone said I could change the printhead myself. (found new one at a parts store for 1/2 the price the tech was going to charge me for it)
OK TO THE POINT!! Is it worth it to fix it? or just buy a new one? Are these machines known for common problems. Am I going to spend a $1,000. to fix it just to have something else go wrong?
Also can you tell me where I can find how to replace the print head & electronic module?
  • Robyn Dunn Aug 05, 2008
    OK! I guess your point was it is difficult? But you did not address the rest of my post! Also when I am on the netware it states 'PostScript Initializing'?
    Genius:
  • 2,028 Answers
I worked for a local Xerox dealer briefly, and I can tell you that Xerox service manuals are kind of hard to get hold of, until the models are about 6 years old and obsolete. They want you to purchase extended service plans, I know, I used to sell them. This is not a bad little machine, but $1000 is more than half what you can get the same machine for online. I would suggest spending the extra money and purchasing a new one (same model), this way you have spare parts.
Posted on Aug 05, 2008
  • 1 more comment
  • Ryan Rogers
    Ryan Rogers Aug 05, 2008
    Oh, and of course, if you weren't pleased with this machine, you can always get something different. There are several manufacturers that make good comparable machines at a much cheaper price, and you won't have to pay for the Xerox name, but don't tell them I told you, lol.
  • Ryan Rogers
    Yes, it's difficult, but if you're mechanically inclined, you shouldn't have a problem, just take your time. The post script message can be due to the module, so, you will need to replace the print head and module first, then address the post script issue, but I think the module replacement will cure this.
  • Ryan Rogers
    I don't see how toddg's post is going to help. You already know that you need to replace the print head, and unless you can get a service manual (which isn't available to the public, yet), this isn't going to help you at all. If you do this yourself, you will need to go slow and keep everything in order. There is quite a bit of disassembly involved in doing this.
    Genius:
  • 3,422 Answers
Your machine will need a service.
For more details please click on the below link:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=114,E=0000000000021314962,K=5248,Sxi=15,Case=obj(22161)
    Genius:
  • 1,011 Answers
Check this manual and then decide yourself after reviewing it
https://www.office.xerox.com/partners/SBSF_docs/SB729.pdf
regards,
I have an error code 07,007.40:10320 any idea what the problem is please?
That is a process motor failure, replace the process motor camshaft kit, part number WCC2424-Z2. The printhead is unable to tilt.
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Sep 03, 2015 | Xerox WorkCentre C2424DN All-In-One Laser...
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
Jul 07, 2015 | Xerox Office Equipment & Supplies
Xerox c2424 fault code 37.002.47:33363
you have problem with your printhead!
Printhead jet-stack heater error
Sep 07, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
C2424: error code 19,993.48:88868
This error is a Printhead error, but in this case is usually more probable to be caused by the Electronics Module.
The Printhead part number is 650-4354-00
The Electronics Module is 119-6427-03
I suspect the actual error code was 19,003.48
Whit
Item, Inc.
Oct 03, 2010 | Xerox C2424 Copier
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
White lines will not go away in our Xerox C2424
Since you have done all that. That tells me you almost certainly have a bad print head.
They will clog or sometimes the jets get damages and it becomes impossible to pass ink through them.
I would say a bad print head is about a 99 percent probability.
May 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Oct 22, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 problem (11,009:46 and 13,008.47)
The second fault is a result of the faulty electronics module. It is a print head heat related issue.
Question is, is the print head also faulty.
That electronics module is very expensive.
But the 11,009 specifically is a failure of the electronics module.
Have had those codes a couple of times.
Most likely the 50 volt source has failed, that maintains the print head heat.
A Drum Assembly thermal error has occurred. The following troubleshooting procedures apply to these errors:
arrwup.gif 13,008.47 The Drum Heater is too hot
Jan 30, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
132 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
