Question about Garden
I bought replacement blades for my John Deere 54 inch cut and they came with a round center hole and the ones already on there have a jagged center. Is there a piece to fit inside round hole to make blade snug?
  • 718 Answers
Those piece you are looking or should have come with the replacement blades , if not you might be able to find them at you local home center ie: lowes ,home depot..
Posted on Apr 02, 2011
I have Z445 54 inch and the middle blade. Is cutting lower than sides. The outer blades are at same height, any help?
Middle lade has probably hit stump and bent. Try moving to outer and see if this does not move problem. If you still have problem at middle look at the blade spindle bearing could have gone bad and shaft dropped.
Aug 05, 2017 | John Deere Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
What is the correct way to Install New Blades on John Deere G100 with 54"cutting deck
Do Ray:
I pull my machine up so the front tires are on a ramp. make sure the key is out of the ignition. Raise the deck to its top position (every little bit of room to work helps!) I think that the spindle nuts are 1 inch. lodge a two-by-four piece of wood between the tip of the blade that you are removing and the blade deck and remove the nut at the bottom of the blade (make sure you are turning your wrench in the correct direction!) It will take a two-grunt pull to loosen the nut. The blade should fall off when the nut is loosened. Make sure to not put the new blade on upside down! (Use the other two blades for reference). Repeat for the other two blades. Make sure that the blade retention nuts are Very Tight.
Jun 15, 2015 | John Deere Garden
Need to install secondery belt on my g100 john deere automatic lawnmower
I need to look at a diagram to replace a belt for G100 54" cut John-Deere?
Jun 28, 2011 | John Deere Garden
What would cause my John Deere Sabre 25hp 54"cut to be hard to steer ?
Your tractor has a simple worm gear turning another worm gear system.Either the one of the spindles in the front wheels is sticking or the worm gear is not meshing or you need to replace the worm gear on the steering shaft it's self.Also,if the tie rods are not set right then the wheels may turn hard,set the tie rods so that they have 1 to 1 and 3/4 inches of tow in in the front wheels.
Sep 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
I have a John Deere model# LA105 , and it is cutting uneven because one blade sets lower then the other,the blades are not bent.
I have a John Deere lawntractor, 105. Won't start. Gas getting to the carb, but not getting into carb. Is this a common problem. Has been setting for a year. Any suggestions on problem
Sep 11, 2009 | John Deere Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
