Question about Frigidaire GLTF530DS Front Load Washer
Hi: Frigidaire GLTF530DSO started to make loud noise. Took apart, found broken shock absorber and replaced. Drum is loose and still makes loud noise. How can I stabilize the drum? Larry Schuettpelz
  • schuettpelz2 Apr 03, 2011
    Thanks! we took it apart and feel repair is not worth it; will check the sale ads today.
  • Frigidaire Master
  • 2,605 Answers
Hello, Welcome to FixYa. I suspect the rear bearing or spider gear is toast, thus the reason the shock absorbers where broke in the first place. Very common for these machines unfortunately. It is a very involved repair either way but if you think you're up to it ( plus, is it worth it ? Parts are in the range of $400-$500 ) I can help in whatever manner possible with those frigidaire washers. I'll watch for your reply. Good luck. Regards, Macmarkus :)
Posted on Apr 02, 2011
In spin cycle the tub had been making loud noise. Then there was a knocking the last time or two. Then it stopped spinning. The tube won't turn at all. Is this the bearing? Does the tub need to be...
Just had the same problem last night; I took off the back and noticed that the 'shock absorber' was broken. http://www.partstore.com/Part/Electrolux/Frigidaire/fwt449gfs1/Electrolux/Frigidaire/134564200/New.aspx
Not sure if the same part is broken on yours.
Oct 23, 2010 | Frigidaire GLTF1670A Front Load Washer
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
My frididaire front load washer is making a loud knocking sound as it goes through the cycle. Also the metal "basket" in which the clothing is places seems to be "off its track" and loose. i can move it...
It sounds like the shocks for the drum are broken. The shocks absorb the wobbling of the drum due to unbalanced loads, etc. Remove the lower front panel (with machine unplugged) and look towards the back on each side and see if you see broken or hanging shocks. The panel has 2 screws I think and should come right off.
Also, if you can open the door and lifting up on the drum inside the machine and moving it around and hear a clunking sound, the drum bearings may be bad. Give that a try and see what you find.
Jun 30, 2010 | Frigidaire ATF6000ES Front Load Washer
LOUD noise when in spin cycle. Appears to be in drum assembly.
The loud noise is because the shock absorbers that hold the tub are broken. This allows the tub to flop al over the place.
You can get new ones easily by doing a search for"appliance parts" then enter your model number and select the part from the menu.
Check a couple of different sites as it seems that no one site always has the best price.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 04, 2009 | Frigidaire GLTF1670A Front Load Washer
The washer drum is hitting in the spin cycle.
When you take off the back panel, check to see if both shock absorbers are intact. We were having some problems with our (ATF6000E) Frigidaire front-loader recently too. I noticed that one of the shock absorbers was broken, for about $25 I got a replacement (two of them, I couldn't find just one). It took about 15 minutes to replace. No problems. With mine, though, I think because the drum was moving around, it dislodged some wires which made it stop filling up with water after a few seconds. I did a test and it said E5E. I would check to replace your shock absorbers before doing any more laundry so your machine will still work and not have other problems like mine.
Sep 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
It appears that my front loader drum is loose and hanging. Make a ridiculously loud noise.
Your shock absorbers are problably broken and need to be replaced. Take off the bottom inspection panel by removing the 2 screws on the bottom of the panel and pull the piece down and out. Then take a look inside the machine in the bottom middle on both sides. There should be a shock absorber on each side and these are plastic. Check to see if they are broken at either end and if they are, go to your local appliance repair shop and buy/order a new pair. The new ones are slightly upgraded by making the body out of metal and the rest out of plastic. Instalation instructions come in the package as well as a pair of new absorbers. Hope this helps.
Aug 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Loud noise on our washer, needs to open it
Plug off the wall, open up behind - some shock-absorber (damper) could be damaged; check for loose or broken springs supporting drum. Lastly if the drum thru the front (front loader?) glass door is totally mis-aligned the problem could be your spider arm, which is not too easy.
May 31, 2008 | Frigidaire Washing Machines
Frigidaire front load washer model GLTF1670ASO
Check the shocks on the bottom of the drum. I had the same problem and had to replace the shocks because they were broken in half.
Mar 02, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF530DS Front Load Washer Logo
244 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
