Question about Electrolux Refrigerators
I've got an electrolux frost free fridge freezer and it is not freezing. The fridge is cool and cold air is entering the freezer compartment but it is not cold enough to freeze the food. I've removed all dust from the condenser but no improvement - any ideas?
  • Anonymous Mar 27, 2014
    the freezer is not freezing the food
    President:
  • 1,462 Answers
Remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Posted on Aug 05, 2008
My refrezrator is not cool properly lg
Most fridges only cool the freezer compartment and the cold air then flows into the fridge section. It could be that the hole to the fridge from the freezer is frosted solid and no cold air can get through, if so, use a hair dryer to melt the frost and open the hole. It is usually near the bottom of the compartment.
Apr 05, 2014 | Home
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Fridge not getting cold,freezer working fine
Most likely you have a defrost problem. On some electrolux models the cooling tube (from the freezer compartment to the fresh food compartment) get blocked by frost. If you do not feel air flow (when the fan is operating) then that is the most likely cause. Which means that something in the defrost circuit (heating element, thermostat or defrost timer) is not working correctly.
But before you check them make sure the fan is operational in the freezer and that the condenser grill under the unit is clean.
Dec 30, 2011 | Electrolux Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Electrolux frost free fridge freezer. Warm fridge and ice in the frost free freezer?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 22, 2010 | Heating & Cooling
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
505 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
