Question about GE WBVH6240F Front Load Washer
I have a model wcvh 6260fww GE front loading machine. It will not spin on the rinse cycle. With nothing in drum goes through wash cycle perfectly with a high speed spin at the end. At the rinse cycle the drum will not spin. Water comes in, sits and is pumped out but no drum movement. Then machine stops and button blinks. Filter is clean, machine looks like new inside. Motor and belt appear fine. Door lock appears to be working fine. With clothes in drum it acts exactly same way. Is this a circuit board problem or a sensor? Drum does exactly as it should on wash cycle.
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
SOURCE: high speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Posted on Mar 24, 2009
SOURCE: No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Posted on Jun 02, 2009
SOURCE: My GE front loading washer Model WCVH6260 does not
This has happened to us also. Our machine is 27 months old. I just had a non-GE repairman out and he showed me the mutilated belt. I was wrapped around the pulley. He said that the pulley had to be out of wack in order for this to happen because the belt looked in great condition (besides being in 3 pieces). Then the metal wheel (don't know the official name) is now warped and had gouged 3 grooves into the cheap plastic outer tub. So badly that it went thru to where the water is. So NOW, I have a big piece of scrap metal in my basement. I need a new outer tub, pulley, belt and at least 2 hours of labor. So a bill of 4-500$. I think GE can take this hunk of metal! But of course, GE has to send out their service man to inspect it. So I have to pay another service fee. They need to scrap this model and possibly others. What a waste of a whole lot of money. NEVER again.
Posted on Oct 20, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
heatman101
Apr 14, 2011 | GE Washing Machines
Kenmore supercapacity 3.5 , model 417.44052400 drum does't spin during the rinse and spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 05, 2011 | Kenmore Washing Machines
I have a GE WCVH 6260 front loading washing machine. It has a massive tear (approx. the bottom third) in the rubber door seal. All the water drained inside the unit, beneath the tub, on down to the floor...
Please join us in this petition to have GE recall this front loading washer! Thanks :)
http://www.thepetitionsite.com/739/633/604/recall-ge-wcvh-front-loading-washing-machines-due-to-smoking-fire-hazard/
Dec 01, 2010 | GE WCVH6260F Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
GE WBVH6240F Front Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
