Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
My son has given me his Whirlpool washing machine but I can't figure out how to take out the soap powder dispensing drawer to clean it. Can you help?
  • 456 Answers
Hi.
pull out the drawer as far as you can.
in the centre you can see a plastic insert (usually a different colour to the main drawer)
you should be able to press this down and this releases the catch holding the drawer in.
it is the same sort of system you find holding a car ashtray in place if that is any help.
Posted on Apr 02, 2011
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Water leaking out of soap dispenser?
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
I need to remove a drawer front for cleaning.
If this is a front loading washing machine..................Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
If helped, click.
Mar 02, 2013 | Refrigerators
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool washer fabric softener container
i would quit using powder soap and use the HE soap.I would take the soap dispenser out and clean it out and also clean out behind the dispenser.run just water thru machine or try washer magic to clean out the machine.you can find washer magic at most home depots or lowes or even a appliance parts house.
Mar 08, 2009 | Whirlpool AWM8143 Front Load Washer
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
Nov 03, 2008 | Miele W865 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
