Karcher B403 pressure washer water leaking and the motor is pulsing but the nozzle is not blocked.
  • 92 Answers
SOURCE: Karcher 211 - no motor action
Dear Tigger82 (also montaver2000),
This explaination is relavent to various Karcher models, especialy your model. When you are using the machine with the gun open....presurised water comes out of the lance. When you close the gun, the machine stops. This happens by means of a Spill Valve or often called the Control Valve. When the gun is closed, this spill valve cotracts with built up pressure and at the same time works on a miro switch which cuts the electricity....and thus stops the electric motor. Now in many cases when the gun is again opened, this spill valve sticks and keeps the electric circuit closed.
In all cases you must open the cover, and locate this spill valve. Sometimes it is easy to see a micro switch on it. If you remove the miro switch from the spill valve the motor will for sure turn.
Now the spill valve gets stuck for many reasons. One of the reasons is that you leave the machine under pressure for a long time and even store away the machine with pressure still in the system. A spill valve also gets stuck due to detergent. I sometimes service the spill valve and lubricate with special solicon grease. But the best way is to change the spill valve with a new one. So in a few words, the spill valve is stuck and leaving the microswitch off. So the electric motor cannot turn. One final hint is that sometimes the spill valve is difficult to remove. So all one has to do is attach water supply and switch on the pump. With the pressure produced the spill valve will be pushed out. In my oponion this job must be done by a person who knows what he is doing. Carefull that you have safety electrical breakers. See that you have safety shoes, safety gloves and eye protection.
Regards,
Fulltech.
Posted on May 26, 2009
  • 32 Answers
SOURCE: Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Posted on Jul 04, 2009
  • 32 Answers
SOURCE: hi,karcher hds hot pressure washer now pressure
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
  • 608 Answers
SOURCE: karcher pressure washer keeps pulsing when not in
This can happen if the head of the pressure pump has split. You may need a new head, and to stop this happening again, tie the rigger open with a zippy tie. The water will run all time now and automatically bleed any air form the system. When you want pressure, turn it on at the main switch. This will prevent hydraulic hammer, (when you pull the rigge)r, which is what causes the head to split.
Posted on Mar 28, 2010
  • 34 Answers
SOURCE: My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
Posted on May 16, 2012
Karcher troubleshooting
check your lance nozzle is not blocked... Remove the lance from the trigger assy and see if you have water coming through then. If you do then the nozzle is blocked :@)
Jul 21, 2014 | Karcher K2.26 Electric Power Washer
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
My karcher seems to pulse when on, could this be due to the low water pressure from the hose?
I do not have specific experience of your machine.
However, the high pressure pump will be controlled by a pressure switch on the high pressure outlet to the pipe and jet.
Pulsing (turning off) suggests that the outlet (high pressure) pipe is blocked or partially blocked. Try checking the nozzle and (with the unit turned off) clearing it with a fine piece of wire.
Hope this works
Nic Williamson
Apr 23, 2011 | Karcher K2.26 Electric Power Washer
I have a Kew Hobby 80. The output from the lance is not constant but pulsates.
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Feb 22, 2010 | Karcher PSI Electric Pressure Washer
Jun 29, 2009 | Garden
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
Mar 21, 2009 | Karcher Garden
Karcher/Winner 11 - motor pulses when hose is not operating
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Mar 15, 2009 | Karcher K2.26 Electric Power Washer
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Washing Machines Logo
621 people viewed this question
Top Washing Machines Experts
