Question about NetGear WNR2000 Wireless Router
Cann establish wireless connection from samsung blu ray to netgear router
  • 556 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
Are the router addresses assigned on the same subnet?
many routers have a base address of 192.168.0.1 and a subnet mask of 255.255.255.0 meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as 192.169.0.1 with a subnet mask of 255.255.255.0 his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say 192.168.2.1 with a subnet mask of 255.255.255.0 his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as 192.168.0.1 the second where the WAN is not used could become 192.168.0.2 (where that address is not in the active DHCP server's assignment range) or 192.168.2.0 (note the DHCP server had better be off or else the empty wan port 192.168.2.0 could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
Posted on Dec 15, 2007
redhaze89
  • 854 Answers
SOURCE: Wireless connectivity b/t Netgear router & Motorola cable modem
Here are some troubleshooting steps that I suggest you try: 1. Check physical connections. a. Connect the modem to the Internet port of the router. The Internet ?i? LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up. 2. Access the router's web-based utility. a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password". Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default. To reset the router: a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in. 3. Configure the router. Since your Internet Service Provider is using a cable connection, please follow the steps below: a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button. 4. Configure the wireless settings. a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number. Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection. f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle. 5. Power cycle. a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online. If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below: 6. Connect wireless computer to the router. If you are using Windows XP with Service Pack 1, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect. If you are using Windows XP with Service Pack 2, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router. If you are using Windows Vista, please follow the steps below: a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect. From the above configuration, please check if you can now access the Internet.
Posted on Jun 15, 2009
  • 19 Answers
SOURCE: Samsung bd-p1600 wireless connection to 2wire 1800HG router
Check CNET Samsung forum. There are several posts with the same problem. A couple solutions and basic confirmation that Samsungs newest fireware is bad. I wish their support helpdesk would realize that instead of telling me to contact my router support.
Posted on Oct 26, 2009
  • 10 Answers
SOURCE: Dynex router blocks connection of Samsung BD-P1600 Blu-Ray to Net
I'm not familiar with that particular router, but all of them are about the same. You can go in and edit firewall settings to allow a particular IP address to have access. Don't disable the firewall completely, just set it to allow that I.P address to have full access.
Posted on Nov 15, 2009
  • 825 Answers
SOURCE: Trying to connect to sony blu-ray wireless where
Certain routers will not have a wps button on it...
You can go for the next options in your bluray...
You will have options to enter network key...(this is wireless network password)
Or you can configure using PIN number...(an 8 digit number printed at the bottom of wireless router)
But if u configured using wps or pin number, then the wireless settings on your router will get sync with bluray player... All your other wireless devices like laptops and iphones and gaming system will lose their connectivity to the wireless router...
so it is advisable to type the security password of your router in bluray player...
Posted on Nov 29, 2010
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
We have a LG Blue-Ray Player Model BD570. The Blue-Ray can see our home network, but refuses to accept the router password. I have a laptop on this router and use it with no problem.
Are you talking about the wireless security password that allows you to establish a wireless connection? Or, are you talking about the CIFS login and password that allows you to see shared folders on your computer.
If you can't establish a wireless connection, try changing the type of security you currently have set up on your router. For example, if you are using WPA, try switching to WEP and see if you can then connect the BD570 to the router. As a last option, you could try turning off all security (for a brief time, of course) and see if the BD570 will connect to your router.
If you are having the dreaded CIFS login and password problem (and you are using a Win7 computer), uninstall Windows Live Login-Assistant and Windows Live Essential 2011. Both programs interfere with the ability to use CIFS file sharing on the BD570.
Aug 20, 2010 | LG BD570 Bluray Disc Player
I have LG BD370, purchased a Netgear Wireless WNR2000 N-router, As recommended in the manual, I purchased a (Linksys Cisco Powerline AV Network kit model PLK300. That was connected w/ Cat 6 cables. Have...
Get a Wireless Access Point ($30-$50 average). A wire from WAP to the Blu-Ray player should work like a charm. The WAP pretty much takes your wireless connection and transforms it back to a wired Ethernet connection for devices like this. You can have your Wireless Router on one side of your house and the WAP on the other, right next to your blu-ray player with a short Ethernet connection between the two. The player will just see it as a standard Ethernet connection.
Aug 07, 2010 | LG BD370 BLU RAY PLAYER
Cannot connect to wireless router
There is another security aspect that might be enable. Its about the mac adress. There is a tab somewhere where you can enable or disable a predefined list of mac adress that will be accepted. So you can usually scan the one around and add the choose one from the list as authorized unit... Also, there is tons of faq and tricks on the netgear website...
Oct 10, 2009 | Televison & Video
PC Streaming does not work.
try to reset all network setting on your pc and router
Jul 08, 2009 | Samsung BD-P3600 Blu-Ray Player
WNDR3300 RangeMax Wireless N Router. I forgot my Network username and Password. How do i reset?
i did download the sofware of the ARES ULTRA and cann,t connecting to the internet
Jan 15, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Loss of connection
This problem is mainly cause by the router firmware, so I advuice you to contact Netgear and ask them to update the firmware of your router to resolve this problem that you have....
Apr 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear WNR2000 Wireless Router Logo
157 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
