Question about LG Dishwashers
A LE error meesage is appeared on the panel and the dishwasher will stop running after about 2 minutes.
    Sergeant:
    Champion:
  • 202 Answers
Hello and welcome,
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Posted on Apr 02, 2011
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
I get an LE error message on my LG Dishwasher. I replaced the pump. Still get the LE error. Replaced the main control. Still get the LE. No blockage in the pump. What now?
When you receive the LE error code, unplug the machine for approximately 15 - 20 minutes. This will reset the microprocessor.
Oversudsing is the main cause of LE error codes. Using non-HE detergents or too much detergent will cause stress on the motor. Oversudsing can also cause leaking and odor.
A breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire.
A couple of notes about this - there are at least three motors on this unit - the main pump, the drain pump, and the 'vario motor' which appears to control the direction of water flow through the sprayers. The main pump is the one likely to go bad. Another cause of the LE code is broken wires in the door. The wires in the door get stuck in the black sound insulation and eventually break. Sometimes, this causes the LE error code. Check the wires in the door first. They are located behind the large front panel. It's easily removed by undoing 6 screws.
Sep 06, 2010 | Dishwashers
I have an LE code how can i reset
Try unplugging the unit for a few minutes. Then plug back in. If not try the Power button. I have an SE code (drainage problem) and my machine stops running altogether.
Sep 05, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Error message LE
1. drain water
2. unplug for 20 minutes
3. spin the drum manually 3 rotations
4. back in business
look at this link below it has "Other" info
http://www.howtomendit.com/answers.php?id=28214
Mar 06, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
"LE" Error Code appears on control panel
LE is a motor error Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked. REMEDY Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Sep 24, 2009 | LG 24" Built-In Dishwasher - Black
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
Dishwashers Logo
78 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
