Question about Kenmore Refrigerators
Can the door of my side by side be adjusted - Kenmore Refrigerators
    Master:
    Sergeant:
  • 385 Answers
Loosen the screws at the top of the door, don't take them all the way out, just loosen.Once they are loose you can adjust the door and then retighten the screws. Having a second pair of hands will help.
Posted on Apr 02, 2011
Saging door
You should be able to adjust the door hinges very similar to a normal household door. You may have to unscrew the hinge and reinsert. This would definitely involve two people.
Sep 05, 2012 | Frigidaire FRS3R5EMB Side by Side...
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    When I close one door on my side by side the other door pop open
    you have adjustments on top of the doors that you can adjust to let doors close tighter, or the unit may not be level and leaning twards the front.
    Mar 18, 2012 | Kenmore 54622 / 54624 Side by Side...
    How do i adjust the doors so they dont touch each other when the doors are closed.i.e. sideways adjust ment,not up and down,i can see how that is done
    It is a leveling problem, not a side to side adjustment normally. If you have a titt - left to right or right to left - then the door are thrown out of alignment.
    So if you put a level at the top and adjust the up and down until it is level side to side.
    Aug 18, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
    Maytag Model MSD2454GRW side by side - the refrig door is not sealing tight about halfway down the door. Is there a adjustment I can make to help to door seal properly?
    Check to be sure the frig is sitting level. You should have leveling adjustment on each side below the doors and behind the grille. Also, on the bottom door hinge (usually fridge side) should be an adjustment to raise or lower the door to align the doors. After that if you simply have a deformed seal you can try carefully heating the seal with a hair dryer to soften it and should smooth out the wrinkles. Be careful not to over heat the seal. Good Luck
    Mar 12, 2011 | Maytag MSD2454G Side by Side Refrigerator
    Refrig door not closing properly, needs a push,
    DOOR IS NEEDING HINGE ADJUSTMENT. LOOSEN SCREWS IN HINGE, ADJUST DOOR TO ALIGN WITH SEALS AND TIGHTEN SCREWS TO RE-ADJUST.
    Feb 20, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Side by side freezer door pops open
    This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
    Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
    How to adjust fridge and freezer doors on Kelvinator C520 Litre
    how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
    Apr 04, 2009 | Refrigerators
    Kenmore Microwave door adjustment
    Depends on the door. It likely can be adjusted they have 2 screws on the door bracket you may have to remove the cover to see them. But it also needs to be checked with a leakage meter to make sure its not leaking.
    RadioShack used to make a low cost meter not certified or anything but a good way to see if its leaking.
    Jan 08, 2009 | Kenmore 62622 Microwave Oven
    GE Side by Side Fridge Door Adjustment
    Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
    Jul 02, 2008 | GE Refrigerators
    Refrigerators Logo
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    jackdo2
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
