Question about GE Dishwashers
WE MOVED IN OUR HOME 17 YEARS AGO. THE GE POT SCRUBBER DISHWASHER HAS ALWAYS WORKED VERY WELL. RECENTLY IT STARTED TO LEAK UPON USE. FIRST OUT OF THE BOTTOM IN FRONT, ALL OVER MY FLOOR AND THEN IT STARTED TO LEAK THROUGH THE FLOOR AND I CAN SEE IT DRIPPING FROM THE CEILING IN OUR BASEMENT ? SHOULD WE GET IT FIXED OR WOULD THAT BE TOO EXPENSIVE?
    Master:
    Sergeant:
  • 385 Answers
If your dishwaher is 17 years old I would say it probably should be replaced.
Posted on Apr 02, 2011
  • 4,348 Answers
The cost of repairs may dictate that you replace the unit, as when you are finished, you will have a machine older than 17 years.....there would be predictable failures in it's future... Consider a new unit.
GE Dishwasher Quiet Power III Dishwasher leaking
The average life of dishwashers is 7-10 ten years so it might just be dying but try this. If the leak is a small one that seems to always be near the left side of the dishwasher put a cup of white vinager in the upper rack and run the unit on pots & pans or heavy duty. This is caused by a build up of detergent that make the unit oversuds, when the suds turn back into water it leaks out the left front corner. The amount of water is not huge, one towel to clean up. If the leak is larger it could be the pump is leaking and you can order a new one with your model # from marcone.com
Nov 27, 2010 | GE Dishwashers
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
My GE pot scrubber won't fill with water, all kof
you are probably in need of a new water inlet valve part #WD15X10003, should be around $35.00. this valve opens up at the proper time on the timer to let the water into the machine. hope this helps.
Oct 15, 2009 | GE 24 in. GSD2600GBB Built-in Dishwasher
When I push the start button on my dish washer, nothing happens. Part of the problem is, is that I never use it, but I don't want it not to work. It was like new when I moved here two years ago, but I...
A dishwasher is like a car and needs to be used once in a while. If you put your car in the garage and don't try to start it for a year, chances are, it will not start. A dishwasher should have at least some water in the pump to prevent the seals from dryng up. If there are any food particles in stagnant water, they will start to grow into a science project given enough time. I have replaced countless dishwashers for people who spend their winters in Florida then come home to a dead or leaking dishwasher.
Hope this helps, Ken
Oct 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Glasses come out dirtier than they went in to the dishwasher but other items clean OK
Remove all dishes and throw two cups of vinegar into your machine then run the complete pot scrubber cycle with the hottest water you can.
Always run the hot water into the sink until it is totally hot before you run your dishwasher.
May 20, 2009 | Dishwashers
Dishwasher won't stop washing
Could be a couple things... but let's address the "not draining" first
Have you recently installed a new disposal? Ensure that the drain plug is removed "punched-out". The plug is located where the air-gap or your dishwasher drain-line is directly connected to the disposal.
This can possibly make the rest of the machine malfunction due to the sensing of "sitting" water that is not draining. Ensure you're pump and filter is not clogged from debris (Inside, right, rear of dishwasher or screen type material)
Other than that, the problem can also possibly be your control board ($100+ dollars for part only)
Jan 25, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
After my dishwashing cycle is complete there is a residue left on the dishes -- I only fill the soap half way and i use a rinse agent.....
Dishwashers work best when the following "rules" are followed.
1. Rinse food off of the dishes before you place them in the dishwasher.
2. Face plates toward the center and do not over crowd them.
3. Always put glasses on the top shelf and always put plates on the bottom.
4. Run the hot water in the sink until it is as hot as it will get before you start the dishwasher.
5. If your dishwasher has a pot scrubber cycle use it and it will make a difference.
Doing these things should solve your problem. If not, let me know.
Jan 04, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Doesn't run
I asked for help when the dishwasher (GE 1991) started up and then quit. Your site was useful as we found a priority list of things to check, thus saving much time and confusion. Our problem turned out to be a disconnected ground wire.
Thanks for the help. You probably saved us a couple of hundred dollars for a repairman. We intend to replace the dishwasher next year when the kitchen is renovated so the timing was important.
Nov 23, 2008 | GE 24 in. GSD4020Z Built-in Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
129 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
