Question about Kenwood KVT524DVD Car Video Player
My Kenwood KVT-524DVD player shifts songs as it wants. It might play 2 seconds or 1.12min of a song before it changes. So it is not the scan function which is activated. I have upgraded the software as well.
KaeZoo
  • 156 Answers
SOURCE: kenwood kvt 717 dvd
I think this may be it, here: http://www.partstore.com/Part/Kenwood/Kenwood/KVT717DVD/Kenwood/Kenwood/J84015005/New.aspx If not, do a search for your model number on the same site. They have over 100 replacement parts for that model.
Posted on Jul 13, 2007
  • 1003 Answers
SOURCE: kenwood kvt-617dvd region codes
THE DEFAULT SETTING IS REGION 1 FOR THE US
Posted on Jan 18, 2008
hawkwatcher
  • 67 Answers
SOURCE: kenwood kvt 715dvd
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. kstahl65@att.net
Posted on Feb 29, 2008
MrScary66613
  • 1990 Answers
All of the Compatible Kenwood Units will have Bluetooth Printed on the Face in Small Letters. If yours Does not, Go to Crutchfield.com and they will have the Connectors that you need for this to be done. Please Rate My Response! Thanks!
Posted on Feb 09, 2009
SOURCE: Need a kenwood kvt-617 brain.
can i have r buy the brain?
Posted on May 13, 2009
Plays only 2 seconds of each song
Press the emergency reset button located on the side of the player. You will need a small pin or paper-clip to insert into the tiny hole. When the button is pressed, the player will turn off. Don't panic - turn it back on and it should function normally.
Sep 17, 2009 | Audio Players & Recorders
Jump to the other song
The problem is that your MP3 player has selected INTRO. This will play an introduction of every song in your folder. To FIX this simply
1. Play a Song
2. Press MODE (button on the left bottom side)
3. Select PLAY MODE
4. Select NORMAL
Problem solved!!
I had this same problem when I first got mine, I really freaked but a couple hours of fiddling around brought me a solution. Hope this helped.
Jul 11, 2009 | GPX ML648B MP3 Player
Element MP3 player plays the intor of songs
Its most likely a problem with the song rather than the player.
Jul 06, 2009 | Audio Players & Recorders
Kenwood KVT-847DVD radom reset problem
I solved this by changing where the power for the DSP unit was coming from the manual specifys to connect them to the same +12 connector for display and DSP and it worked fine in the Series 1 however for some reason in the series 2 the DSP unit draws too much power from the headunit +12 power connector and as soon as the unit fires bass in a song etc it drags it down to the point of the display shutting off, I change the +12 on the DSP unit to my 4GA +12 power cable through an adaptor block and it has worked fine since.
Apr 17, 2009 | Car Audio & Video
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
Songs
The WMA songs that you have are DRM-encrypted, and they do not have "transfer rights" - as in, you cannot play them on your Mp3 player (either that, or they are only sample songs)
Solution 1: Upgrade your music service subscription
Solution 2: Convert the Songs to Mp3 format
Read up on DRM encryption - you can find more info in my 2-part "Tips & Tricks" under my profile - on song formats
Jun 20, 2008 | SanDisk Sansa c240 MP3 Player
Kenwood KVT-617DVD
hi kenwood go's off when i put it on to dvd
Jan 16, 2008 | Kenwood KVT-617DVD Car DVD Player
Ringing sound when playing music
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 22, 2007 | SanDisk Sansa e260 MP3 Player
Kenwood KVT524DVD Car Video Player Logo
35 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
