Once the setting for progressive scan output is entered, an image will only be visible on a progressive scan compatible TV or monitor.
If you set Progressive Scan to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc tray. See that 'dISC' is displayed on the display window.
2) Press STOP (on front of unit) and hold it for more than five seconds before releasing it (10 seconds is better).
The video output should be restored to the standard default setting (interlace) and a picture will once again be visible on a conventional analogue TV or monitor.
Hopefully that solves your problem.
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
