I was working with jturcotte and got cut off - Heating & Cooling
  • 6,993 Answers
Do still want to continue with jturcotte or talk with someone (me) else?
To get back to jturcotte, go to your FIXYA Activity ("My Activity"), you will find your question there with Premium Chat. Click on it and you will find the the (transcript), conversation between both of you.
Go straight to the end of the page, and click on "leave a comment for jturcotte". He will receive your comment and get back to you.
But if you want to continue with me, you can give me a feedback on what the problem is.
Take care.
Posted on Apr 02, 2011
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
What are cut-resistant gloves?
Cut resistant gloves are gloves designed to protect hands from cuts while working with sharp tools. They can be divided into metal mesh gloves, cut and sewn and seamless knitted gloves.
Feb 06, 2013 | Clothing Accessories
To JTurcotte - Your discussion and directions on how to repair the 1990 Jeep Cherokee srteering column were very good. I have a similar but not exact problem. The key would not come out of the...
WHEN YOU INSTALL NEW LOCK CYLINDER, TURN THE KEY TO THE LOCK POSITION. INSERT THE LOCK CYLINDER INTO THE HOUSING FAR ENOUGH TO CONTACT THE DRIVE SHAFT FORCE IT INWARD AND MOVE THE IGNITION SWITCH ACTUATOR ROD UP AND DOWN TO ALIGN THE COMPONENTS. WHEN THE COMPONENTS ALIGN, THE CYLINDER WILL MOVE INWARD AND THE SPRING LOADED RETAINER WILL SNAP INTO PLACE LOCKING THE LOCK CYLINDER IN THE HOUSING.
Sep 11, 2011 | Jeep Cherokee Cars & Trucks
Will this saw be able to cut steel on truck and trailer frames? the steel may be 2-3 inches thick in some places. other places only about a half inch thick. is this a good tool for cutting heavy metal?
Never heard of cutting steel with a chain saw. What works best for me has been a sawzall with a good quality steel cutting blade. The real thin metal cutting blade on a circular saw works pretty good also.
Mar 28, 2011 | Husqvarna Garden
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
May 03, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Cut video clip does not work
try to format it once using *#7370# the default security code is 123456
Mar 21, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
Hand jig saw stops cutting - makes whirring noise - then restarts
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
May 21, 2009 | Saws
IBM T40 2373 display cuts off.
When it cuts out can you still see the display very faintly or does it just go completely black?
Mar 10, 2009 | IBM ThinkPad T40 2373 Notebook
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
