Question about Kenwood Audio Players & Recorders
My frequency indicator on my Kenwood TS 930-S fades out periodically. Sometimes it returns, sometimes it doesn't. What do I need to do?
Thanks for your prompt response. I found the Kenwood Service Bulletin posted on the internet to deal with the PLL unlock. I appreciate your service.
Posted on Aug 06, 2008
SOURCE:
I have a KENWOOD TS-940SAT HF Transceiver that powers up with the TX indicator on, no power output and no receive.
Very little information about the situation of the transceiver is provided, it might be a complex one. The Kenwood TS-940SAT features a built-in automatic antenna tuner covers the amateur bands 160 through 10 meters. It is advisable for you to reinstall the transceiver and follow the right set up step to see if it works out eventually.
Apr 18, 2016 | Computers & Internet
Hi I have a kenwood ts 440s the radio turns on ok but the frequency counter display does not come on
Wow, what a nice radio! Very complicated controls, here is a link to the operating manual. I suspect the radio is showing a memory channel number instead of the frequency. It should be easy to fix, but long manual. If you cannot find it in the manual, erase or "clear" all memory entries.
http://www.manualslib.com/manual/86439/Kenwood-Ts-440s.html?page=7#manual
Oct 11, 2015 | Kenwood Radio Communications
How to install a voice synthesizer into a Kenwood ts 570
This should be of some help to you...
http://www.manualslib.com/manual/86121/Kenwood-Ts-570d-Ts-570s.html?page=64
Mar 02, 2015 | Kenwood Radio Communications
My kenwood kr-v7030 won't turn off anymore with remote or manually.
Either the remote battery are flat or the frequency settings have changed. You can check with the manual the type of frequency it uses to match the that of the Kenwood. Sometimes there are switches you can change to adjust the correct frequency. Others have a learning code set by the manufacturer and are usually in the operation manual. If you want to test whether the remote is transmitting the signal to the Kenwood or not, Please do this...
If you have a digital camera or smartphone camera, switch the camera on and look at the viewfinder or camera screen; for smartphone, in a moment, then point the remote to the camera lens and press the volume button, which keeps sending the signal to the to control the volume of Kenwood system. If you see the infrared light on the remote flashing, then the remote is fine.
Now, about the smartphone camera. Start the camera and switch it for video capture (filming) and then point the remote towards the camera lens, and likewise you should see the remote light when doing the same tests as you with the video camera. If the infrared light lights up when pressing on the volume, the remote is fine.
It could be Kenwood, which requires factory repairs, not by you.
Dec 22, 2014 | Kenwood Audio Players & Recorders
My Kenwood Radio (New) for my boat doesn't tune properly on FM. For example, it only tunes to 94,1 or 94,3 but not to 94,2 It is just ,1 digit off the frequency on most stations. Tried it on manua
Kenwood receivers are usually tuned for their intended destination country, hence the frequency "stepping" of the tuners may differ between countries.
Was this receiver originally intended for your country's frequency? If yes, then contact Kenwood customer service for further advice.
If not, contact your local Kenwood service agent and ask whether the frequency stepping can be reprogrammed.
Feb 20, 2013 | Kenwood Car Audio & Video
Front panel turns off
Have you performed a FULL reset on the TS-2000?
To perform a full reset:
With the power off press and hold down the A=B button and with the other hand turn on the TS-2000.
After that you will have to press the A=B one more time. The radio will reset itself,
and the display will show 14.000 MHz in the main band, and 144.000 MHz in the sub band.
Please let me know if it worked for you.
Tommy
KG4TDM @ arrl .net
Sep 12, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
Autotuner problem with Kenwood TS=450SAT
Sorry, I did not realize that this was a fix-it-for-hire place. I thought it was a place for free advice
I will take my problem elsewhere.
73'
WB9RWW
Jan 03, 2009 | Radio Communications
TS 2000 KENWOOD TRANCEIVER
I have the same problem with my TS2000 , in VHF I can heard small signals only if I turn on the PRE Amplifier ...
It start just few hours of use .
Jul 31, 2008 | Computers & Internet
171 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
