Question about Brother MFC-8460N All-In-One Printer
I have a brother MFC 820N. The paper lifter in the paper tray is not working properly so it dose not load papers into the printer. when I lift the papers by hand from below everything works fine. would be grateful for any tip Thanks
SOURCE: Brother MFC 8460N All in one
Remove your tray.
Push it from the back and make it sure it's tight against the paper.
Move the blue button to the "unlocked" position.
Should be good to go!
Posted on Jun 18, 2008
  • 215 Answers
SOURCE: Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Posted on Jan 09, 2009
  • 215 Answers
SOURCE: MFC886DN will not pick up the paper in the lower tray.
first, most common problem is the rear stopper in the cassette is pressed too tightly against rear of paper. leave 1/8" gap between stopper and rear of paper. if that doesn't help, pull cassette out and locate gear on left side of cassette bay and make sure it is not dislodged.
good luck,
razors
Posted on Apr 15, 2009
  • 133 Answers
SOURCE: how to clean the paper feed for brother mfc 7820 multiple jams
It's difficult to said just by typing, you better get your printer services person to clean it for you.
Posted on May 22, 2009
xptareq2000
  • 1447 Answers
SOURCE: I have a brother MFC-9440cn printer. The printer
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Posted on Jan 14, 2010
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
How to print on legal paper brother mfc 8680dn
Hi G gur,
Go To Below official Brother Printer Page For Your problem,
How do load legal size paper in the paper tray Brother Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Nov 15, 2013 | Brother Mfc-8680dn All-in-one Laser...
Printer jams frequently. Jam is in the paper tray. It appears to try to pick up a sheet of paper and can't. When you open the paper tray the sheet of paper has been lifted up, but not enough to pull it...
Locate the paper lifter and the initial rollers and clean these with isopropil alcohol and a Q tip. These items become hard and polished and will not grip the paper properly, causing the jam.
Jan 20, 2011 | Brother MFC-9440CN Laser Printer
Brother printer keeps reading "no paper".....it has paper in it.
try paper in mp tray if that works your bottom tray may not be lifting
May 18, 2010 | Brother MFC-8860DN Printer
Brother MFC 8860: Display reads
I have exactly the same problem with my Brother 1250 mono laser printer.
Any solution yet?
May 11, 2010 | Brother MFC-8860DN Printer
I have an error message, Brother MFC-8640D Printer
NO PAPER MP
Load paper into the Multipurpose (MP) Tray There is no paper on the Multi-purpose tray. Load paper onto the Multi-purpose tray.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/002100/000073/faq002173_005.html?reg=eu&c=eu_ot&lang=en&prod=hl3260n_all
Thanks
Jan 15, 2010 | Brother MFC-8640D Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
Problem for Brother MFC-8460N error message no paper in tray tried cleaning. re loading, on-off. etc.
Make sure the paper guide is not too tight, also set the paper tray on a table and look at the gear on the side at the bottom. The flat part of that gear must be level with the bottom of the tray, if not the metal under the lifter is bent and needs to be straightened. also tip the printer on it's back and make sure the sensor levers by the feed roller move freely.
Dec 24, 2009 | Brother MFC-8460N All-In-One Printer
Clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
Jun 24, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460 N, all in one copier. Loud clicking noise (from tray area) when trying to make a copy, it will not do a copy now, says to load paper - tray has fresh, higher quality paper in it. Is this...
Make sure the stopper in the paper tray is snug against the paper. sounds like the paper is not properly in place and the tires are making the noise.
Could be it's trying to lift the tray and it can't, determine why; something stuck, out of place,
Jul 21, 2008 | Brother Office Equipment & Supplies
Brother MFC-8460N All-In-One Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
