Question about Watches
How do you set day of week,day and month properly on Kronen & Sohne Troubillon?
Which Kronen and Sohne Tourbillon do you have?
Posted on Jun 28, 2011
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
I can't set the day of week on my Casio, CA-53W. Thanks
If the day of the week is incorrect, make sure the date is set correctly. The format on the Casio CA-53W is year first, then month, then day last.
May 31, 2011 | Casio New CASIO CA-53W Water Resistant...
I purchased a Marco Max watch with day, date and moon phase. How do I set each of the dials to match the correct day of week, month and hour?
The crown has three positions. The A position is when it’s pushed all the way in. You can’t set anything in this position. The C position is when it’s pulled all the way out. The B position is the click between all the way in and all the way out. My biggest problem is that I read the directions to mean that there were FOUR positions. I didn’t realize A was all the way in. I thought there was three pulled out positions.
To set the day of the week (Sun, Mon, etc.): Pull the crown all the way out (position C) and turn the time to just after midnight. The setting will click to the next day. To advance it an additional day, you don’t have to turn the hands another twenty four hours. You can turn the hands backward to before midnight (you will see the day of the week setting click a little, but not go backwards), then turn the hands past midnight again.
I recommend setting the day of the week setting to YESTERDAY. You’ll see why later.
To set the date: 3341598183_60e77d12e5.jpgPull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
I recommend setting the date to YESTERDAY. I’ll explain why later.
To set the moon phase: Pull the crown one click out (position B) and turn the crown toward you (counter clockwise). To find out what phase the moon is currently in, here are a couple of websites:
Once again, set it to the moon phase for YESTERDAY.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your Luar watch is ready to go!
Review 3342440924_5fa48ca4fe.jpgMany of the Swatch enthusiasts were disappointed that the Luar is a battery powered watch instead of an automatic. With a price tag of approximately $450, it’s a little much to expect an automatic with a real moon phase. I’ve talked at length about what I desire in a watch here:
My desires have changed a lot since that day nearly four years ago when I went looking for the perfect
To set the date: Pull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your watch is ready to go!
Aug 11, 2010 | Watches
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Setting Date & Day
Two clicks to the dial on the right. First click adjusts the day of the month. To change the day of the week pull out to second click and go forward or backward in 'time' and week will follow.
Apr 11, 2009 | Watches
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Anne Klein chronograph watch
The button advances the numeric day. After the numeric day is advanced one full month, the month dial advances to the next month. I just about got a blister pressing the button enough times to advance the month from January all the way around to December. Then I had to advance the numeric day to the current numeric day. The previous person told you by turning the dial 24 hours you can advance the alphabetic day of the week by one day (Sun, Mon,etc.).
Sep 04, 2008 | Casio G-Shock G7100D-1V Wrist Watch
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 | Watches
Watches Logo
449 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
