Question about Dishwashers
What do you suggest to do for dishwashers that are idle for 6 mos
  • 415 Answers
Do put a couple of glasses of water in the tub close the door and push cancel. This will keep the seals depending on some models from overheating and seizing. Do this a couple of times then select a short wash cyc and ensure no water leaking. Resume as normal
Posted on Apr 02, 2011
Hard to start, idles rough and bogs down when you give it gas
sounds like your truck needs retimming....
Sep 14, 2012 | 1990 Ford F150
It is 6 mos old and it leaves the dishes dirty and with a white film on everything. I used jet dry, cascade with no results. what would cause this? it has done this since day one. thanks
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
Chainsaw strarts OK but stalls
Most likely fuel "Air" problem.
Old fuel can and will gunk up the air flow jets.
Would suggest cleaning the carb and filters.
Then replace with good fuel mixture and start again. :)
Make sure the choke is set correctly and the air filters are clean.
Had a lawn mower that would NEVER crank correctly after sitting idle for the winter. Had to dis-assembly the carb and clean literally with paper clip and tooth brush. Never once had to change the spark plug or wires. After spring cleaning (LOL) it would usually crank on the 2nd pull.
Mar 28, 2010 | Garden
I have mold in my dishwasher. This happened about 6 mos ago and I used the vinegar and scrub method to get rid of it...it was a pain in the fanny! Now the mold is back...the dishwasher has also not been...
Get rid of the mold - Pour about 2 cups of bleach in the dishwasher with about 1 cup of salt, and a gallon of cold water, use the light wash, not heated. Make sure when you start the cycle it doesn't drain first or you lose the bleach. Also I don't use jet dry in my dishwasher, I use bleach in place of jet dry and I've never had a mold problem. Good Luck and let me know if this helps. Thank You
Mar 23, 2010 | Dishwashers
I have a built in Kitchen Aid Dishwasher and my rinse aid dispenser has been full for weeks
since it only uses a few drops each cycle it it quite possible it looks full
a full jet dry resivoir, will last about 6 mos
Oct 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Engine will not crank over the battery is good and everything else will work
try the starter relay located by the battery where all the battery hook ups are at the terminal
Jul 26, 2009 | 1997 Dodge Caravan
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
