Question about Peak Performance Peak PKC0BL 450 Amp Jump Starter with Power Inverter and Inflator
I charged my Peak amp 450, however,it only stays charged for a little bit and then it doesn't work again.
Brand new ,had 79 percent charge from store,i went to use it . wouldnt start car.plugged in to charge read fl [flashing] says nothing about fl in owners manual.whats up with it.thanks ralph
These "cheap jump starters" are little more than a Lead/Acid battery much like what is in your car. If they sit too long on the shelf of your local department store, without having a charge maintained, the cells in the battery will eventually collapse rendering them next to useless without quite a bit of work trickle charging them back to life. As the proud owner of several of these useless boat anchors I can advise you to save your money and just buy a really good vehicle battery (Interstate) that will be there when you need it, instead of wasting money on Wallymart specials that last 2 maybe 3 years. I have learned..... ;-) Take it back and get your money.
Mar 28, 2016 | 600 Amp Jumpstarter - PKCOAO
Where can I get a manual for a Peak Power Station 450
Just Google the brand name & model and then select the correct manual.
Feb 21, 2015 | Vehicle Parts & Accessories
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
Won't charge
Won't charge, what should I do ?
Apr 18, 2014 | PEAK 450 Plus Portable Power System
I need to know how to recharge my 450 amp jump starter
There is a charging port on the front of the unit next to the LED work light.
The wall charger it came with, is a 12VDC 500ma.
Positive center coaxial connector.
Radio shack usually can match the unit if you bring it in to them.
My charger was pouch Velcro-ed to the unit.
Kings Model KU3B-120-0500D
Jan 27, 2014 | PEAK PKC0BJ 450 Amp Jump-Starter USB Power...
I need a 110/120 volt ac/dc adapter power cord for recharging from standard wall socket. For a Peak 450 jump starter
After searching the internet for a ph number for Peak power I finally found the web.
http://www.peakauto.com/contact/site.
phone 800-323-5400
If the part department doesn't have the answer ask to be switched to tech support.
They were able to provide me with the part numbers I need for new wall supply cord and an DC adapter for the car.
My jump starter is no longer made...
Nov 15, 2013 | Peak Performance Peak PKC0BL 450 Amp Jump...
Charging a peak power portable power system 450 plus
Do I have to recharge it regularly before the battery goes down to uncharged. I'm talking abt peak 450 plus
Jan 07, 2013 | JUMP START SYSTEM
I can't find a cable to charge the pkc0aq Peak Amp power station plus
You open the door that covers the plug on the lower side and find a extension cord and plug it in and then in to a wall outlet for about 24 hrs
Nov 23, 2012 | PEAK 700 Amp Jump Starter with...
Batteries not charging in 83 Ford 6.9L diesel.
Your alternator should be putting out 13 to 14 volts when all your lights are on and radio and so forth. If it is only putting out 11.9 peak your alternator is putting out less then a fully charged battery. The alternator is shot or regulator.
Jul 28, 2009 | 1984 Ford F 250
Peak Performance Peak PKC0BL 450 Amp Jump Starter with Power Inverter and Inflator Logo
Top Peak Performance Electronics - Others Experts
Are you a Peak Performance Electronics - Other Expert? Answer questions, earn points and help others
