Question about Canon DR-9080C Path-Through Scanner
DR-9080C BackgrounfColour Dropping Out
Occasionally while scanning in colour to uncompressef TIF format,the background colour partially drops out to give a sort of banding effect. I have cleaned the shading plates, lens, sensors. I've even tried putting a plain white piece of paper through to see if that re-sets the white balance. My only thought now is that the actual scanning element might be on its way out. But when it does happen, i have tried swapping it with an alternate 9080C and the same efffect is still there. I have also tried 3 different versions of the captureperfect software and the PC it is running on is of pretty good spec (dual core, 2 gig ram). Any ideas???
  • 490 Answers
Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
Posted on Nov 08, 2008
SOURCE:
Black background when scanning in greyscale
There is an option to set the brightness/contrast in the first page of Capturperfect. Select automatic if you cannot manually set it.
S. Mohan
Mar 29, 2012 | Canon DR-9080C Path-Through Scanner
P002
The error reported should be 'P02' and not 'P002' This means that the length of the paper is more than the size selected. For example if you scan legal sheet after selecting A4, you will get this error. Select Autosize (with CapturPerfect ver 3) or select 'Scanner Maximum' and remove black background. You can also select a specific size with 9080C.
S. Mohan, Chennai, India
Feb 16, 2011 | Canon DR-9080C Path-Through Scanner
When we try to save the scanned documents it takes long time? any idea how to slove this issue please...thanks
The file size depends upon B&W or Color, the Format and the System performance. If you are scanning in color, try JPG format as it is lesser in size. TIF file will be huge as compared to JPG, though there is a drop with JPG, it is easily manageable. If B&W go for TIFF compressed instead of uncompressed TIFF.
Check if you have enough disk space in your computer. Do a defrag on you hard disk.
S. Mohan, chennai, India
Nov 30, 2010 | Canon DR-9080C Path-Through Scanner
Scanner Canon DR-9080C recently started scanning at a slower speed. All setting look to be the same compared to another unit. Any thoughts?
Do you have enough disk space? Try disk Defrag and create more space. Also check the Format you are saving, is it TIFF compressed or uncompressed? The uncompressed file size is really huge.
Oct 02, 2010 | Canon DR-9080C Path-Through Scanner
"Skip Blank Page" but still inserts one
I have two of these scanners the only way that i have found round this is to scan the pages duplex then remove the unwanted afterwards!
Aug 26, 2008 | Canon DR-9080C Path-Through Scanner
How to get rid of the 4 zero's at the end of the naming convention?
The scanner allows you to scan in batches and you can select a convenient name for a batch. If you start the first batch as 'A', then the first image will be 'A001.tif' , second as 'A002.tif' etc. If the next batch is 'B', then it will be, B001.tif, B002.tif etc.
S. Mohan
Jul 28, 2008 | Canon DR-9080C Path-Through Scanner
How do you get rid of the 4 digits that is added by default to the file name?
If you are in the 'batch' mode, the software adds this. If you select one page scanning, you have the chioce to select the file name you want. Actually after scanning, u need to save it in the neame U want.
Cannot select a lower bit depth in colour than 24 bit?
With better processors and large storage, higher color depth is the order of the day; however if you dont want higher color depth, you can convert the images after scanning. Ofcourse it requires an addl effort.
May 21, 2008 | Canon DR-9080C Path-Through Scanner
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
222 people viewed this question
Clive
Clive
old marine
old marine
Ekse
