SOURCE: philips 42pf7320a/37 dead
I do agree with the tech but if the green led don't come on and the 7-blink error code is still there. check the connector from the logic board that will be the board under the small signal baord. The small signal board have the AV input on it. Check the connector from the logic board to the power supply there should be one connectore btween those 2 boards. On the power supply side second pin from the left it will say Vs_On if the set has 0 volts the proble is the SSB or the logic board. how to determain that is to Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU (see figure below).
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (this will supply a 100% White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
SOURCE: Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
SOURCE: Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
Testimonial: "IT WORKED! I TRIED EVERYTHING! This was on my mind all night. THanks for the help. helping real people solve real problems!!!!!!!!!!!!!!!!"
