Question about Lanier 1205 Copier
Cannot insert Tray 1 into the machine. it says to "Reset Tray 1 correctly". What are they saying.
    Problem Solver:
  • 5 Answers
It is not seeing tray in the machine. Might be a piece of paper stuck behind the tray stopping it from going in and stopping it from detecting the tray?
Posted on Apr 04, 2011
I Have an EPSON Stylus TX700W Printer , & am having problems getting it to feed paper. Have tried all the Paper Jam solving problems to no avail. Printer just keeps saying "The Paper Cassette is...
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jul 10, 2011 | Office Equipment & Supplies
The display says, "insert disc",
Thank you for posting to Fixya.com and it is my pleasure to guide you.
1. The disc may be turned over. Insert the disc with the playback side facing down.
2. The disc may be dirty. Wipe it with the correct type rag.
Since you stated the display is showing then I take it the player is on and the chord is plugged in.
3. Is the disc completely centered in the tray? I have done that before.
4. Have you run the self-diagnosis function? If the Error code 'AACS ERR' shows then it is an "AACS read failure". Remove the protected disc. Then turn the unit off and wait a minute or two and back on.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 18, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Camera says "Please e-operate after pushing reset
Remove the battery and keep aside for about 15 minutes. Now after inserting reset the camera., if the fault occurs., remove the tape and use a hair dryer to blow into the tape tray section/drum section.
It is possible that the dew sensor is working to indicate moisture, if so the heat will change the fault.
Also if the hall IC's within the drum is faulty the drum will not move and so will indicate a fault-- service.
Dec 24, 2010 | Panasonic NV-DS37 Camcorder
Just cleaned our Thermador BICM24CS Coffee maker but we get an error message "empty trays". I emptied them, cleaned the contacts, reset the start button. Still has that error msg. If I remove...
Did you ever figure out a 'fix' for this? I am about to take a sledgehammer to this machine - the 'empty tray' message is preventing us from using it at all!
Dec 16, 2010 | Thermador BICM24CS Espresso Machine &...
A paper jam was not cleared in a timely manner, now the machine will only display "Error Code C0202, Call Technician" It is Saturday and I can not get a hold of anyone at our support center. How can I...
C0202= tray 1 elevator failure.
Open tray 1, check and make sure paper is loaded correctly.
With tray open, open and close front door. This will reset error code. With tray 1 open look to see if paper is stuck behind tray in back of machine, if so remove it ( this will block the lift motor for the tray).
Close tray 1, if you hear a popping noise the lift motor is damaged and will have to be replaced. Until it is replaced operate machine with tray 1 out to prevent error code.
Sep 18, 2010 | Konica Minolta Bizhub 362 Copier
"replace paper tray, not correct size for cartridge" shows up whe
A couple of things. Make sure you tell the machinne the size of paper, and also check to see that not only the size of the peper but the type of paper On the machine and the print driver match.
One of the most common issues with that message is that the machine will say Plain paper and the print driver says Bond or Recycled.
Now, if that is not the indication, what you want to do look on the right front side of the paper tray itself. There are small tabs, about 1/2 of an inch by less than a quarter inch. They insert into small holes in the tray. They often times break or just fall out on their own. You can just take a piece of tape, obviously not clear tape and cover the holes.
You could have a paper tray sensor that has fallen off. There are black actuators that hang down in the tray that actuate when the paper tray is inserted.
Jan 29, 2009 | Xerox Phaser 8560DN Laser Printer
Stuck in print mode with out taking paper from tray
i think may be i can help, well rick there is no reset button on brother machines,..have you tried cleaning the paper feed roller? may be some thing did print and the paper is still crumbled up in the machine. try this. cut a file folder to 8x11 and manually force feed it through the paper path, there may some thing inside the machine that might be holding a sensor down. this is the first thingwe would do as a brother tech. good luck by the way clean the rollers with denatured alcahol
Jan 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
I am using a fax machine Canon L80 and waiting to receive a fax ... it's blinking between and says "received in memory" and "check paper size" ... not sure what to do.
"Check paper size" means that the paper in the machine doesn't match the size selected in the setup.
To change the paper size:
1. Press the Function button.
2. Press the Data Registration button.
3. Press Set button.
4. Use up or down arrows until you see PRINTER SETTINGS.
5. Press Set button.
6. Use up or down arrows until you see PAPER SIZE.
7. Press Set button.
8. Use up or down arrows until you see type of paper in the paper tray (LTR, LGL, A4).
9. Press Set button.
10. Press Stop/Reset button.
Machine should now print out the fax that was received in memory.
Jun 20, 2008 | Canon Office Equipment & Supplies
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
67 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
