Hi the light on the wg111v2 keeps flashing on and off all the time. but the internet works ok is this ok peter.
    Sergeant:
  • 313 Answers
Yes, the blinking is telling you that the internet has an active connection.
Posted on Aug 05, 2008
We had a power outage and now my netgear router is not working exede said my firm wear needs updated how do i do that have called net gear 5 times and keep getting the runaround. i bought the router l
Hi
Do you mean it doesn't power on or won't connect to the internet?
If it powers on OK do the lights flash as described in the manual
If the router worked before why should you need new firmware, doesn't make sense.
Nov 15, 2014 | NetGear N600 Wireless Dual Band Router
Fridge red light keeps flashing
Hello. My Name is Peter. I am a former Sears Service Tech. I need a model number to help you.
Oct 14, 2014 | Refrigerators
The blue light on my wg111v2 in not flashing. is it because i did a system recovery on my pc with the usb plugged in ?
You will need to install the drivers for the wireless adaptor. The flashing blue light simply indicates that there is activity (communications) with a wireless access point.
You can find the drivers for it here;
http://netgeardownload.registria.com/single_page_registration?product[sku]=WG111v2&download_url=ftp://downloads.netgear.com/files/WG111v2_v4.0.0.zip
~KenjiFox
Jan 07, 2011 | NetGear WG111V2 Wireless Adapter
Wg511 v2 'sees' the network but just won't connect just keeps scanning, updated to latest driver but still no go. Pulled out old WG111 v2 USB wireless card and it connects straight away. Pull the Wg111v2...
Follow the step below to configure wireless connection.
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 30, 2009 | NetGear WG511T 802.11g/b Wireless Adapter
Epson Stylus Photo 1270. All lights flashing. Whats wrong and how can I fix it?
Hi Guys
I had the same problem with all lights flashing nothing working, happened after a panic power shut down. As with peter after the paper button was released, printer lit up like a christmas tree again. I played around with the button combinations and found that holding down the ink button instead of the flashing paper button cleared the problem. Great tip guys saved me a lot of money. cheers me dears clive.
Mar 02, 2009 | Epson Stylus Photo 1270 InkJet Printer
Wg111v2
Hi!
Well, it asks you for the login code, if you havent set that code then its set by the manufacture, it should be in the manual who came together with your netgear, it looks like something like this:
ACFG-ABF2-0EDF-11AD-CDFE-A,
Try to find it in the manual.
Good luck to you
Nic
Feb 06, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Canon IP2000 printer. The power switch is flashing intermittantly green and orange and as a result it seems to be stuck as anything I do has any effect - any ideas?? Many thanks in advance for your...
this may work for you
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Nov 29, 2008 | Office Equipment & Supplies
Disconnection problem
have you configure your netgear wg111v2
Oct 02, 2008 | Computers & Internet
On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Nov 10, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
