Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch logixx 10 washing mashine
How do I open the filter door on the above machine as I suspect it is full of animal hair.
  • witsuebea Aug 05, 2008
    bosch logixx 10 wbb24756gb
  • witsuebea Aug 06, 2008
    Bosch logixx 10 wbb24756gb Washing Machine only
    there is nothing about the filter door on the manual that I downloaded
    I cannot open the outer door, I have tried turning, pushing, getting my nail under the edge and pulling all to no avail, the outer door will not open, any more suggestions please?
    President:
  • 1,462 Answers
Just turn filter cap. outer door is just a hinged flap
Posted on Aug 05, 2008
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
Bosch error E23 flashing
disconnect the power the door unlock within 30 secound
Oct 12, 2014 | Bosch Washing Machines
I am getting the F-18 message on my Bosch Logixx 8 washing machine. I have to keep emptying the tube as I am unable to twist the coin filter. Reading previous notes I got a pair of pliers to try twist it...
it can be done by yourself as long as you feel comfortable in doing so as it can be a bit fiddly.
you will need to unplug the appliance, unscrew the pump housing from the cabinet, disconnect the hoses on the pump housing this will enable you to find the obstruction, remove it and subsequently unscrew the filter. then reassemble
Apr 07, 2014 | Bosch Logixx WFT 2806 Front Load...
Bosch logixx 7 door wont open
After trying to find manual and doing it the right way with no success my son solved the door problem with a metal fork. Where your hand meets the handle (inside the door drum) shove the fork in to force the clip open. Not the outer edge of the door, theres no locking system there - behind the actual handle.
Apr 03, 2012 | Bosch Logixx WAS2446 Front Load Washer
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
Can I get a user manual for a Bosch Logixx 1400 washing machine?
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
Sep 24, 2010 | Washing Machines
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
Bosh logixx
Click on your model number above (below FIXYA ) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Feb 24, 2008 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
543 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
