Question about HP LaserJet P1505n Printer
Engine scanner error - HP LaserJet P1505n Printer
When sending document to my HP LaserJet P1505, the engine scanner error message
Posted on Apr 25, 2011
2055hp laserjet printer show 52scaner erorr
It is a big error. Cannot be repaired by most people without skills and sophisticated equipments. Moreover the scanner motor will be expensive to find and replace.
52.X PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Apr 29, 2016 | Office Equipment & Supplies
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Error 52.00
Please see below the error description and possible solution.
Hope this helps
Jan 23, 2014 | HP LaserJet P4015N Printer
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
Hp laserjet 3055 has code 52 scanner error and wont print or copy
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
My printer shows printer error 52.0
Jul 08, 2009 | HP LaserJet 4100 Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet P1505n Printer Logo
368 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
