Question about Frigidaire FEQ332E Electric Dryer
My frigadiare dryer has stopped working my dryer is only about 2 years old - my husband has replaced the motor and belt but still this has not solved the problem.
  • 1 more comment
  • sandiegreeng Apr 02, 2011
    My dryer is a front loader model number is AE06700FE0 could this still be the problem?
  • sandiegreeng Apr 04, 2011
    I have replace the thermal fuse and still the dryer wont work any other ideas on what this could be
    I have replaced the thermal fuse today and still the dryer will not work. I have already replace the motor and belt what is left ?
  • 4,323 Answers
Hi
As you have already replaced these parts which I don't think was required so now test the parts first before replacing. Three parts are left before we come to a conclusion that it is the control board that should be replaced. First, test the thermister (part#15 in this diagram) for continuity, second part that should be checked is the thermal limiter (part#36 in this diagram) for continuity. If both of them are fine then check/test the door switch. Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch each tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero. If the test you conduct does not produce these results, you should replace the switch. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 04, 2011
  • Daniel Scott
    Daniel Scott Apr 04, 2011
    Hi
    Daniel
    Hi
    Daniel
  • Frigidaire Master
  • 8,220 Answers
On the rear bulkhead is a thermal fuse. If blown the dryer will not run:
I have a service manual and more HERE
Posted on Apr 02, 2011
Ge electric dryer. suddenly stopped working. Will
Hi Stv,
There isn't really major problem, but a problem.
You will need to unplugged your unit and take it apart. Are you handy?
If and when the unit is apart look at the motor and the fan exhaust and see if there is a coin or screw is jamming the motor or the fan
while you are in there you may want to clean it up,
That should be the problrm
Jul 25, 2010 | GE DBSR453EBWW Electric Dryer
I can here the motor try to run but it will not spin. I was using the dryer and when I removed one load and replaced it with a new load all it does is make a hum. The dryer is only 2 1/2 years old.
dryer belt is either broken, or came off of the motor pulley, check varify and replace if needed. If belt is ok, you may have an article of clothing stuck in the blower wheel, remove as needed.
Jun 30, 2009 | Dryers
Dryer won't start
belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Jan 22, 2009 | Dryers
My whirlpool estate dryer tub will not rotate
To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Estate EED4300SQ Dryer
Dryer runs then stops.
IF LESS THAN 10-YEARS OLD/CHECK THE TUMBLER BELT AND BAND.IF 10-YEARS+ REPLACE YOUR MOTOR OR BUY A NEW DRYER.***ALSO UNPLUG THE DRYER AND MAKE SURE ALL YOUR WIRES ARE TIGHT.
Jan 17, 2009 | Kenmore 74602 Gas Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
My dryer is about 10 years old. I had a belt replaced last year and currently it has stopped working. When I open the door the light comes on but when I press the start button I get nothing. My husband...
102610f.jpgHave you checked the Thermal fuse?It is also a good idea to check your door switch and the wires coming from it because they sometimes hang into the tub and wear out.
Jul 22, 2008 | Whirlpool Dryers
It is 4 year old.For 2 months after starting,there was funny sound,and it would start.but from yesterday it stopped totally.last evening when i started,there was smell of something rubber burning,and the...
IF IT IS A WHIRLPOOL DRYER, A FEW YEARS BACK THEY CHANGED THE IDLER PULLEY FROM A WHEEL DESIGN TO A TEFLON GLIDE. THIS DIDN'T WORK AND THEY HAVE GONE BACK TO THE PULLEY DESIGN. IC THE BELT BROKE OR BURNED IN TWO, YOU WILL NEED TO REPLACE THE BELT AND IDLER TOGETHER. GAIN ACCESS BY REMOVING TWO SCREWS UNDER THE LINT FILTER. LIFT OUP THE DRYER TOP AND REMOVE ONE SCREW FROM EACH FRONT CORNER HOLDING THE FRONT TO THE SIDES. THEN TILT THE FRONT OUT AND LIFT OFF OF THE BOTTOM SUPPORTS. NOW YOU HAVE ACCESS TO EVERYTHING.
REMOVE THE DRUM AND INSPECT THE IDLER. IT SETS BELOW THE MOTOR PULLEY AND KEEPS TENSION ON THE BELT.
Apr 16, 2008 | Dryers
Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Dec 03, 2007 | Kenmore 63942 Dryer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Frigidaire FEQ332E Electric Dryer Logo
120 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
