SOURCE: Beer Not Cold!!!
There is a temperature control knob on the back side of the ref. it is on the bottom by the compressor
Have you adjusted this?
clayfoot
SOURCE: frost in top freezer - water leaking in refrigerator - ice maker not working
If your frig is freezing the food in the chilling compartment as well
as the freezer, it means one thing--its thermostat isn't shutting down
the compressor when the set temperature has been met. You stated that
you had it checked by, I assume, a professional service technician.
Being a retired tech myself, I'm surprised that he didn't check this
out and discuss it with you. Check the temperature IN THE FREEZER! If
it is less than 10 degrees F., turn the thermostat to "warmer". If the
temp in the freezer is 10 degrees F., leave it alone and go to the temp
control in the frig, which is a damper that controls cold air flow from
the freezer compartment. Close this damper until your temperature in
the upper part of the refrigerator is 38 to 40 degrees F. If these
efforts don't shut down the compressor and correct your problem, then
the answer is simple. Your thermostat is bad and needs to be replaced.
It isn't expensive, and should cost you less than the labor for a tech
to install it. Good luck!
SOURCE: accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
SOURCE: Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too
cold, your drainage pan and tube freezes up (behind the back panels in
the freezer) and when that gets full it spills over too the bottom of
the fridge and keeps building up until you notice.
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
SOURCE: My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp.
The problem could be the electronic control if
you have one or the mechanical linkages.
