Question about Espressione Cafe Roma Deluxe 1329
I can't find a supplier for a replacement filter cup seal. It is torn and the machine is now nonfunctional. It seems to be 72x57x7mm.
Leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
Apr 10, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
My10cupcoffeemakerleaksfromlefttopsideontocounterwhenbrewing
Is your space bar not working either? ;-)
This is most likely a seal that has gone solid over time. Contact the suppliers for a replacement seal.
Alternatively - take it apart, clean thoroughly with alcohol - and apply a thin smear of clear silicone over the seal. Leave overnight - then re-assemble.
For larger seal replacements - use "instant gasket sealant" - solid setting type. Wonderful stuff - and saves on manufacturers who refuse to sell replacements.
Oct 10, 2009 | Bunn 10 Cup Home Coffee Brewer
Black stains sticking to white clothes on washing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 08, 2009 | Washing Machines
Water drippin from the hot water outlet on a Bunn coffee maker
Hello. If this is the hot water faucet, on the front of the unit, there is a rubber seat that keeps it sealed. Usually it gets a piece of debris, or scale in it with use, or the rubber seat gets worn out and needs replacement. To check, turn off your water, unplug the unit, and drain all the water out of the faucet until it stops, then tilt the unit forward slightly just to get a little more. Now you should be able to unscrew/disassemble the faucet, and pull it out to look at the seat cup, and the faucet interior. If there is scale or debris on the cup, and the faucet interior, it will need to be cleaned, and it may actually require chemicals for scale, if bad enough. If the rubber seat cup is torn, it will need a new one. You can get a new seat at a parts supplier for commercial units in your local area, look in the phone book under "restaurant equipment repair" or go online, plenty of them have a web site. If it is NOT your faucet dripping, we can go from there.
Hope that helps, and thank you.
Mar 05, 2009 | Bunn CWT 15-APS Coffee Maker
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Need info how to use
You can use a filter if you desire, or if you like finely ground coffee. A normal filter, flattened-out and a small hole torn in the middle will fit into your basket.
Amount of coffee depends on the quantity that you're making and how strong you like it. Suggested amount is 2.5 cups for a 45 (or 42) cup urn, I personally, use 3.5 cups.
Sep 19, 2008 | Salton Melitta MEU45 Stainless Steel -...
After using coffee that was too small, I can't make coffee with one of the filters
I'm not sure you can. I did exactly the same thing, the very first time I used it -- I phoned Breville support and they told me to try soaking the filter in 2 tsp of baking soda dissolved in a cup of warm water. Which kinda seemed to work, although it was bit occasionally reluctant to give me my damned coffee.
I struggled on with it for maybe a year, but then the rubber seal around the bit the filter connects to blew out (with rather dramatic results). I think the extra pressure of the blocked filter did more damage that I suspected.
I got it serviced and they replaced both the seal and the filter. Worked great after that...
...until last week, when water started pouring out where no water should pour. Turns out that the black lock block that the filter holder goes into has developed a crack.
Looks like another trip to the service agent for me.
In short, you could try cleaning the 1-cup filter, but I would reccommend giving it up as a bad job and just buying another.
Before It Is Too Late.
(Signed, The Harbinger of Doom. Sorry about that.)
Apr 10, 2007 | Breville ESP8XL Espresso Machine
Espressione Cafe Roma Deluxe 1329 Logo
23 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
