Question about ASUS P5LD2-VM Motherboard
Sata hard drive
I want to replace my 120 gig hard drive with a 500 gig sata hard drive.
What do I have to do first??
  • 2,794 Answers
Check to see if your motherboard has a sata controller on it. The user manual will tell you. You can get a new on on asus.com. If it does support it, you will need sata drivers for it which you can download from the website as well.
If it doesn't work you can add one external by picking up and external drive case for sata controllers. Then all you need is a spare USB 2.0 port. Make sure you get one with a power supply for it because at that size getting 500 gig to work will require extra power to perform properly.
Posted on Aug 05, 2008
SOURCE:
I asked you that the system booting take several munite to start of my Brookstone DJB80GB sound cube. and you asked me to replace a new HDD, but I do not know how to install an OS,
hard drives now come in two categories
the old disc type ( most common in use ) and the new solid state hard drive that has no moving parts
the old type ( costs from $40.00 up wards has a working life that depends on the quality and time used
They can be sata connected or the older method ( not going out of commission) They can be around 500 gig but are relatively slow when compared to solid state units
the new solid state hard drives (SSHD) cost around $2.00 a gig so a 120 gig will cost around $60.00
an sshd of 250 gig will replace a 500gig disc hard drive and work faster
because there is no disc to search from a solid state hd will start up faster than the old type
if you want your unit to start faster without the added inconvenience of having to install an OS the you can defrag the existing disc and use a disc cleanup program
Defragging occurs when data is fractured and stored all over the disc instead of in the one section and the action gathers all of the same data and places it in the one section of a disc for quicker reading
disc clean up removes all that rubbish that is accumulated by use and reduces the chis necessity to read every bit to find the correct data sought
when you have a problem like this, it is always a good idea to find a reliable computer repair shop that likes to assist users with out a high pressure sales attitude and get as much information to help understand what you need or how to work with what you have got
new is not always better and upgrades are not always the answer
Jun 16, 2016 | Hard Computers & Internet
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
IS THERE ANY replacements for YH278 HITACHI 120 GB SATA HARD DRIVE HTS541612J9SA00, THAT IS CAN I REPLACE WITH 250GB.
Generally speaking, you can replace any SATA hard drive with any other SATA hard drive. Notebook SATA drives are all the same size, basically, (2.5 inch), and desktop drives are generally the same size (3.5 inch), Desktop and notebook SATA drives will connect to the same power and interface cables, though desktop drives require more power. Just make sure that you pick a 2.5" drive for your notebook, or 3.5" drive for your desktop, and the drive will attach with no problems.
As for the size of the drive, to my knowledge, any system with SATA should support any size SATA drive (I put a 500 gig drive in my notebook, where the stock drive was 160 gig).
Feb 28, 2010 | Dell Inspiron 6400 Notebook
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Syntax SV266A Motherboard Hard Drive update
i,d suggest an 80-120 gig hard drive should be sufficent.
if you require larger drive storage. you can add an external hard-drive via USB upto 500 gig usually without restriction.
You can also purchase An PCI Card, with sata connectors. should you wish to take that option. all the above is dependant on how modern your computer system/systems bios Is.
Mike @ Compurepair.
Mar 25, 2009 | Computers & Internet
Seagate 500 gig external hard drive problem
Your computer must have a firewire connection.
Jan 11, 2009 | Computers & Internet
Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
May 30, 2008 | Acer Aspire 5100 Notebook
How to transfer
If u want fast transfer use this software:
http://rapidshare.com/files/67700211/WinHIIP.zip
if u want manually just COPY -PASTE TO WD
Nov 13, 2007 | Western Digital My Book Essential Edition...
ASUS P5LD2-VM Motherboard Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
