Question about Kenmore Dryers
Dryer operates perfectly except there is no heat. What do I need to replace or look at? Thanks
    Scholar:
  • 86 Answers
First check your breaker. You may be only sending 120 volts to the dryer. It will work all day long on 120 volts, but it won't heat. If that checks then unplug the unit. Take the back off. Should be about 9 screws including the plug plate. You'll need an ohm meter. On the right side you'll see the element with two red thick wires on it or one black one red. There may be another on. Check for continuity between those terminals (red wires). If that's fine check the high limit switch located above the element. It's just a little black round "disk" . Check for continuity there. You should have continuity there as well. If not and I don't recommend this, you can by-pass that limit switch, but replace as soon as you can. It's a safety feature that doesn't allow the dryer to get too hot. If that's all good then I would get a tech out there...hope this helps.
Posted on Apr 02, 2011
  • 415 Answers
You can look at something simple first. Do check the household power if you have fuses then maybe one can be blown if you have breakers switch off and back on if still no heat then you can look to a thermal link depending on the style of dryer if you have a back panel that is held on by 9 screws unplug the power cord from wall then you, will need a OHM meter and set to read Ohm's remove the wiring on the white 1 1/2 long plastic piece to see if you have a reading if no replace the thermal link. Then if good then unplug the wiring to the heating element and check for a reading good? Then put wires back on and up from the heating element there is a stat unplug take a reading if none replace the thermal cutoff kit. And after that being said if no back panel then you front type disassembly is different but check the same described items.
GAS dryer will operate, but not heat. No error codes showing
If not heating at all try this. Go to electrical panel box and find the breaker labeled Dryer. It should have 2 joined together levers. Turn it off and see that the dryer is OFF (this verifies you have the right one) Operate this breaker back and forth (on and off) at least ten times. Then put it in the ON position and try dryer again. If it works you have a bad (intermittent) circuit breaker. Get an electrical handyman to change the breaker. If changing the breaker does not fix it you may need an appliance repair person. Why this is. The cycling on and off of the heat at the dryer is rough on circuit breakers. If this dryer has been in place for some years and replaced another dryer it is probable that the circuit breaker was not changed. BTW the dryer functions (except heat) operate from one side of that 2 sided breaker, while the HEAT operates from both sides at HIGH current.
Mar 23, 2014 | Frigidaire GLEQ642A Electric Dryer
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Hi, Dryer cycles are working perfect, except there is not hot air...only cold....problem? and easy fix please? Thanks.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 02, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 500 series dryer blows cool air only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Zanussi TC180W Electric Portable Dryer
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
Dryer works perfectly except there is no heat to dry clothes.
First check your venting if all is clear It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 09, 2010 | Magic Chef CYG4000AWW Gas Dryer
My hotpoint ctd00 wont heat up
I would suggest that you check the heater and thermostats, these are located behind a removeable cover at the rear of the dryer.
You will need a meter to test them with, you are checking for continuity
Feb 10, 2010 | Hotpoint Dryers
I have a 1984 Honda accord and everything works perfect except no heat. Fan works but no heat. I replaced the thermostat and the heater core (2 days) and still no heat, any ideas? Thanks for any help. F
You need to check that the engine is full of coolant as sometimes the engine will get air locked when you change a component. The next thing is to make sure that the engine is reaching operating temp. If that isn't the problem the blend door in the heating system is probably to blame. I'm pretty sure that on your vehicle it is cable operated so you should be able to follow it from the hot/cold selector in the dash down to where the blend door is. It may be stuck in the cold air position and not letting the hot air in. Unhook the cable and make sure that you can move it. You may have to open up the ducting and see why it might not be moving and it may have an obstruction or it may need to be replaced.
Dec 20, 2009 | 1984 Honda Accord
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
