Question about Brother Office Equipment & Supplies
I can see trash on the scanner, how do i get to the scanner to clean it
  • 2,460 Answers
They make cleaning sheets for the document feeder, which I'm guessing is where you see the junk. It's about $10 for the overpriced special sheet and some alcohol looking stuff. Outside of that, probably a wet paper towel and plain water will clean the glass. If you sent a staple or paper clip through the document feeder and have scored the roller deal, you're on your own :-)
Carl
Posted on Apr 02, 2011
Black line on copy
Lines on scanned or copied pages is usually caused by ink and trash on the scanner glass. Check the glass on your printer for something blocking the light on the scanner. Here is a link to an article about this issue and where to clean.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Aug 21, 2012 | HP Officejet 5610 All-In-One InkJet...
How do I fix a dark streak down center of scanned document on HP laser jet 3330
Lines and streaks are usually caused by ink or trash blocking the scanner pickup. You need to open the top of the scanner and clean the scanner glass. Here is a link to a guide that shows where to look for something blocking the sensor.
May 07, 2012 | HP LaserJet 3330 All-In-One Printer
Green line on i900 microtek scanner too
Try checking the ribbon cable going to the scanner head, it may have a bad connection causing an error as it flexes at a certain spot.
Aug 09, 2009 | Microtek SCANMAKER I900 Flatbed Scanner
Black line on page vertical on receivers end
May be you have, a trash or something on the scanner glass or scanner section lamp.Try to disassembly and clean the lamp.
Jul 21, 2009 | HP Photosmart C5280 Printer
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
May 03, 2009 | Epson Perfection V500 Flatbed Scanner
Stopped at start-up after months of no problems
Please trash the twain driver completely.
- Trash epson scan and epson scanner monitor from applications.
- Go to hd. Go to library, then application support. Trash epson scanner module.
- Go back to library. Click on image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on your computer name. Click on Library. Click on preferences. Click on the epson folder. Trash epson scan.
- Empty the trash and restart your mac.
Log on to epson.com. Install the epson11926.dmg.
Apr 28, 2009 | Epson Expression 1640XL Flatbed Scanner
EPSON STYLUS CX4800
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
Feb 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus DX4450 scan macintosh problem
Trash and re-install the drivers.
To uninstall the drivers:
- trash epson scan and epson scanner monitor from applications.
- go to library, then application support, then trash epson scanner module.
- go to library, then image capture, then trash twain data sources.
- go to the harddrive. Then to users, then click on the name of your computer. Then click on library, then preferences, then epson, then trash epson scan.
Then log on to epson.com and get the compatible driver for 10.5.6. Install it on your computer.
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
